00 black CSVT - my dd
99 silver CSVT - 3L turbo project
What the hell is a spring plate? The retainer clip?
2000 "Amazon" Tropic Green CSVT #836/2150
tomato, tomatoe, whatever you want to call it. Metal clip/plate/spring that holds the end of the soft line in place.
00 Silver Frost SVTC #1429/2150: Born 10 Jan, 2000
3.0L, Spec Stage 3 Clutch, LSD, Koni Sport Kit +more
Do these lines even make that much of a pedal feel diff?
If the standard pressure is at 60%. How much better can the lines add to the brake system? 5,7,10,15,20%??
Yes, a braided line will stiffen up the pedal feel noticeably. The PO of my car did the fronts only because of the rear adapter issue so its already semi-stiff.
It really doesn't matter the exact date, nothing csan really be said something was one way on this date, then on the next day it was this. Parts for vehicles are made one way til the order by the customer changes, then it gets changed over as soon as possible. The new part, and the old part still make it to assembly, and not particularily in the correct order.
2000 Contour SVT
SF - #542 of 2150
3L: SVT Cams/LIM/UIM/Optimized TB/MAF
HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
Tuning: Xcal2 with PRP
Susp: Bat Euro Kit
i just want to make sure i have the correct rear lines.
i have never changed my lines so I'm going to say this is a female hard line.
and I'm guessing the longer end of the new lines goes into the caliper.
-Jon
99 SVT Contour T-Red. #2437
www.myspace.com/ripscottfrost
Actually from that picture it looks like the longer end goes into the fender fitting and then gets held in place by the clip.
you know what, i think your right. thanks for your input
-Jon
