Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: suggestions for mufflers on true duals
    Nov 2006
    oneonta,ny
    2,393
    Default suggestions for mufflers on true duals
    currently i'm running kyle's old setup. 2" true duals. carsound high flow cats,maggy resonators, look like 15-16"s long. and supertrapp mufflers on the end...i really don't like the raspy/blatty sound it makes. so any suggestions on mufflers..i'm all ears. would a crossover tube/H pipe help reduce the noise?
    May 2006
    Plymouth,MI
    2,584
    Blog Entries
    1
    i local SVT owner had a x-pipe and magnaflow resonators and magnaflow mufflers( one piece with teh tips),
    i think it sounded amazing.
    '98.5 2.5L Mystique LS T-Red
    '98 SVT E0 BLK/MNB#1663 Port matched 3L
    Carbonfiber= Played out.
    Nov 2007
    Astoria NYC
    874
    So is it to loud or is it the tone? or Both?
    Jan 2005
    Sandwich, Massachusetts
    879
    tryout the Flowtech warlocks! my buddy has them on his stang and they sound similar to flowmaster super 40s not as loud as the original 40 series but great tone the best part is you pull out the cork and they are like striaght pipes for when you feeling some the need for more noise, just a suggestions, i say be original and do something like that.
    #1119
    Custom interior
    17" Excel Maj's Gunmetal
    15% Tint
    3L Escape 3.0 20k
    Xcal 3 from nautilus performance
    MSDS headers
    trubendz 3" test pipe with Magnaflow Cat
    cherry bomb resonator
    knauberized
    hightowers w/ eyelids
    stazi g2 grilles
    Jul 2004
    Michigan
    6,105
    Quote Originally Posted by 95pgt-t View Post
    The 15 inch resonators arn't doing much of anything at all.
    You have to go with a magnaflow mesh with fibers inside the mufflers as resonators in a tru-dual exhaust to quiet it down.
    Trapps who had tru-duals recomended that to me. Which he says made his sytem quiet. So i have edelbrock 5503mufflers as my resonators.
    Borla is the best way to go, but i got my edelbrocks on that clearance sale for 70 dollars for both
    I'm building my system. I'm buying things one step at a time.
    So far i have.
    stainless pipes
    10k miles rear svt mufflers
    flex pipes.
    resonators
    all i need is high flow cats, and me welding everything together to finish it off.
    Take off those 15 inch resonators and replace them with magnaflow screened fiber muffler.
    ALSO INSTALL an H-Pipe or X-Pipe!!
    FS:65mm Throttle bodies - SE TB - Zetec TB
    Never explain---your friends do not need it and your enemies will not believe you anyway.
    Jul 2004
    Michigan
    6,105
    Quote Originally Posted by Beans View Post
    Yeah pauls old car. Which you know i helped him on.
    Also jeff getlucky151 tru-dual system.
    I've just been spending my money else where the last few years. But i'm getting mine put together.
    Nov 2006
    oneonta,ny
    2,393
    thanks for the suggestions guys. i was also thinking the maggy's might be too short. harry,you have a link on those resonators your using? so a H pipe should be a def'n? k
    Jul 2004
    Michigan
    6,105
    Yes a h-pipe or x-pipe is recommended. Stazi recommended that i install one, When i spoke to him about tru-duals.Demonsvt also installed an H-pipe when he had tru-duals.
    It def helps with the pulses through the exhaust which allows better release of gases. Also it changes exhaust tone and notes when driving
    Um let me look around online. If i can't find any, I'll snap some pics of the boxes they came in. How do you like it on your car? Power gains etc.
    I liked Paul's old x-pipe style. then Jeff did an h-pipe. Because they were separate cars it felt like the x-pipe sounded better to me Also installing any cross pipe, make sure to place it where our y-pipe met the cat pipe. Its important to keep the cross point where the stock location was for tuning reasons.
  9. #9
    Nov 2006
    oneonta,ny
    2,393
    thanks alot!! i was just going to ask about the location..i think h pipe will be easiet. as i'm running cats. so maybe a H pipe right before the cats will help. i havent had it on the road,just tooling around my property. i imagine the gains are there,as i had the stock y pipe w/headers chocking me off some. my only thought is any gains had will be negated by the fact that this setup is so damn heavy i'm going to tool around w/the numbers of disc's again and i'll hold off replacing the trapps at the moment. perhaps repacking them and the h pipe will tone it down just enough to remove the blatty sound
  10. #10
    Jul 2004
    Michigan
    6,105
    Place in a h-pipe but it won't take away rasp, sorry if i confused you if you thought that. The rasp is due to no baffels in the system. Because baffels are so restrictive people tend to opt for a free flowing exhaust and live with the rasp.
    See i'm picky as hell with my exhaust. I have done 4 different exhaust styles.
    that being said i know what i need to make my tru duals flow just right and make good power.
    High flow cats and good resonators and the rasp will be gone. Then pick the exhaust tone with a rear set of mufflers and your set.
