Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: in need of clutch
    Default in need of clutch
    so im looking around for a new clutch. i just dont think im going to run a spec. so i have been searching for outs in other cars that match. i have come to find that the cougar 2.0 has same clutch and svt focus seems to be same. dont really understand why svt contour has like the same clutch as zx3 focus.
    but anyways, need opinions on what others have used. i have been looking at clutchnet and possibly going that route. i really wanted act, but havent found svt focus nore cougar on their list.
    1997 Saturn SL2-project car (salvaged now, current tear down)
    1996 Ford Contour-DD, up and running again
    STC-OH member
    My SL2 and other cars
    Sep 2000
    7,332
    If you are working on a V6, the factory SVT clutch is a worthy upgrade and will hold all the power you can get of of a 2.5 as well as hold up to all but forced induction 3.0 conversions. Check out Bill Jenkins at Team Ford in Las Vegas.
    Jim Johnson
    98 SVT
    03 Escape Limited
    ah sorry, thought it was in my sig. but its the zetec.
    STC-OH member
    Sep 2000
    Louisville, Ky
    9,565
    get the factory SVT clutch or a SPEC stage 1. I dont think the SVT Contour clutch is the same as the focus zx3. Their throw out bearings are definetely different.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    ah i dont need a throw out bearing. its already new. i was just looking at disc diameter and spline diameter/count. the svt contour has pretty much the same size disc as a normal zx3. the svt focus, cougar, and probe 2.2 turbo seem to have same clutch dimensions.
    but right now car is on thin ice. more problems have popped up that now need adressed.
    STC-OH member
    bringing this back...................
    ive been looking and now have been thinking about a clutchnet kit for a 2.5 cougar. same diameter and splines of course. but was wondering if anyone has used clutchnet kits? im really interested after seeing an "extreme" pressure plate, if it truly lives to what they say. i like the clutch stiff.
    STC-OH member
    Sep 2000
    Louisville, Ky
    9,565
    Quote Originally Posted by saturnspeed_12 View Post
    Almost all of us go with the tried and proven SPEC clutch kits. I honestly dont know if you could possibly get a better clutch for our cars. Get a SPEC 1. You could throw everything youve got at a SPEC 1 clutch and wont let up one bit. It easily could withstand a Vortech SC and I think even a T-28 ADC turbo kit. Y2KSVT's beats the absolute crap out of his SPEC 1 and its held up fine to occasional powershifting, numerous passes at the drag strip, and 75 shot of nitrous. 30K miles later, its still holding up nicely. Seems like an easy decision to me.
    Jim Hahn
    ive never heard spec as tried and proven. ive heard tried and busted. all i get is bad things from spec. dsm guys have issues, saturn, bimmers, corvettes, etc. im not risking my chances on them.
    they have not proven anything to me to buy their clutch. im afraid to buy a clutch from spec, clutch masters, and centerforce. i have absolutely roasted a centerforce dual friction clutch in my saturn. make it through the break in period, then get on it, and i burn the clutch. i then proceded to take out my frustrations, so i destroyed that clutch which made me happy. i then stick a cheap stock clutch from aav in and held everything i put at it.
    and i want a stiffer clutch pedal. all the spec clutchs i have felt are like stock. stock pressure has no feel to me. pretty much, ive seen like a ratio of 80% for problems with spec, and 20% good. i just dont have the trust.
    STC-OH member
  9. #9
    Sep 2000
    Louisville, Ky
    9,565
    Tried and proven amongst the Contour/Cougar community. Best bang for the buck clutch for our platform, hands down. There honestly, just isnt a better clutch. I think just about everyone here can back me up on that one. Some people might have problems with a SPEC clutch every blue moon but I cant recall when someone had a problem. Thats true with every clutch manufacturor, but I think SPEC makes a quality clutch. The mustang guys love them.
    If your looking for a stiffer than stock pedal feel though, SPEC isnt going to give you that. Youll probably have to have something custom made if your going for that or buy a car with a larger aftermarket clutch selection.
    Jim Hahn
  10. #10
    oh yeah, i need a stiffer pedal. a 2 year old kid could easily operate this clutch. and yeah i know, car wasnt made for performance. just that i have to drive it and having to operate the clutch sucks, as i do work my legs out (450lbs+ leg press on my small 160lbs body). i usually have trouble releasing and grind the clutch out, because i think the clutch is engaged, but isnt.
    so yeah i need stiffer, so spec wont work anyways.
    STC-OH member
