Results 1 to 7 of 7
Thread: first time open tracking, tire wear?
    Jun 2000
    Cleveland, OH, USA
    419
    Default first time open tracking, tire wear?
    I'm going to open track my car for the first time this June 20th at Nelson Ledges, in Ohio. 2 miles, 7 turns.
    http://www.nelsonledges.com/TFMap.aspx
    You're allowed to race all day. Sessions are 25 min I believe they said. What kind of tire wear should I expect? I'm not going to be going all-out, this is my daily driver and can't afford to go off and risk damage. The tires are probably around 1/2 worn now. Should I expect them to be completely to the wear bars by end of day?
    Also, if indeed I will likely loose 4/32nd or 5/32 of tread, do I rotate tires in the middle of the day? What do you guys do?
    Brian D.
    Past: 99 SVT Contour, May 1999 to Aug 2009 -- good times !!
    Current Ride: 05 Pontiac GTO, 6.0 LS2, 6 speed manual, bought with only 2,300 miles
    Sep 2000
    Westland, MI
    5,367
    It depends on the tires and your driving style. If you are driving like a monkey, overheating the tires and sliding all over the place, then yeah, you'll probably kill them in a hurry.
    You really should be fine as long as you don't behave like an idiot. Remember, open tracking is NOT RACING. Go out there, and run at a speed that is comfortable for you. Work on being consistant, not fast. You'll have more than enough fun, and it will be a lot easier on your car, your tires, your brakes, everything. Listen very carefully to your instructors as well. Running the correct line, and being smooth is far easier on your car and you as a driver than trying to muscle it up and slide the car around every corner. Plus, you'll end up a lot faster when its all over if you follow the line and stay smooth.
    Balance is the Key.
    rarasvt@comcast.net
    Mar 2004
    Louisivlle Ky
    5,209
    thats my plan for SZ basically. start with slow(er) runs to work on mastering the line for the turns and then slowly build from there. i am bringing an extra set of wheels/tires/brakes just in case but i dont plan on needing them.
    basically, go out there, work on your driving skills, and have fun. dont worry about how fast your going compaired to everyone else.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
    Quote Originally Posted by Rara View Post
    I learned that a long time ago. I slowed down and worked on hitting my exit points and i shaved off seconds from my lap times. Plus you don't make your passenger quick as motion sick!
    3L 99 Rio Red Cougar , 91 306 Dech Coupe, 96 Contour ,
    If you wanna Play, you gotta Pay! RIP Maverick
    As mentioned, tire wear should not be an issue. I had new tires on the car before running at Gingerman all day last SZ (before everyone else showed up for the evening) and I also ran all day at Autobahn (full track - 3.5 mi) in October and my tires still have lots of tread left.
    You should just get a good scuff off them over the day, and you'll notice when you leave the track that you have less tire noise going down the road. Well, I did anyway after my first track day on half-used street tires.
    Be smooth, drive 8/10ths and you'll be fine.
    Bob Johann
    SoundQ SVT
    1998 T-Red SVT Contour #3088
    5-Time Sound Quality Champion in IASCA, SLAP, and MECA
    ive autocrossed for a few years now and never noticed any major wear issues driving at 110% the whole time. yes autocross is a lot less driving but i have gone days where i decided i was gonna go home with half the rubber left and could barely make a difference on them even with 200 tread wear rated tires. you should be fine. as everyone else said take it slow and learn your limits first. some of my fastest times have been when i was not trying at all and just found a nice smooth line.
    the main thing to remember is "slow in, fast out" that will yield the best times.
    oh and dont forget to have fun
    Tom Ellison
    99 se 5-speed
    3L hybrid swap 11/20/07
    Quote Originally Posted by 99RedCSVT View Post
    Cost:
    Slide hammer kit = $130 refundable deposit
    Drill bit = Free if you you have one laying around
    Drill= same as above
    Feeling of getting that piece of crap out of there = priceless.
    Nov 2005
    wales ma- it's next to holland (check the map)
    1,239
    my autocross tires this year are kuhmo v710s, and my open track tires will be hankook rs2's
    2004 F150 XLT/ 93 RX7 touring-soon to be ls1/65 Mustang fastback- project EFI 351TT
    SOLD: 98 SVT #2663,89 Mustang GT Twin Turbo, 00 SVT #985-SF,98 SVT #948 BLK/Tan E0, 99 SVT #587-T-green,98 SVT #3969 blk/MNB
