Results 1 to 5 of 5
Thread: High flow cat.??
  1. Default High flow cat.??
    check engine light recently came on in the csvt, so i took it up to advanced auto parts to see if they could hook up their computer. it turns out that the cat. is backed up and needs replacement. i looked at modifying the the whole y-pipe, but i think im just going to try to fine a less restrictive cat. any suggestions?
    Jul 2004
    Michigan
    6,107
    Quote Originally Posted by crazyj View Post
    I bought mine off ebay for around 45 dollars.
    They are smaller in length so an added pipe is needed.
    FS:65mm Throttle bodies - SE TB - Zetec TB
    Never explain---your friends do not need it and your enemies will not believe you anyway.
  3. Default
    ^ was it a universal high flow cat.?
    Jul 2004
    Michigan
    6,107
    Sorry for being short on my response. Yes it was a universal high flow cat.
    This is what i ordered.
    http://cgi.ebay.com/ebaymotors/2-25-...spagenameZWDVW
    Feb 2003
    Phoenix, AZ
    1,952
    You can also get high flow cat pipes from trubendz. Just a drop in replacement, and is 2.5" in, 2.5" out... unlike the CSVT 2.5" in, 2.25" out.
    morbid
    2000 Contour SVT (black)
    #61 (Sept 17, 1999)
