Results 1 to 3 of 3
Thread: defective bearing ?
  1. Unhappy defective bearing ?
    I had new struts,springs and strut mounts on 97 GL V6. Today I find there is squeaking noise comes from the left front suspension when I turn the steering wheel slowly with the car in "P" and engine running. If someone turns the wheel I could see the upper spring seat rubs the strut mount and makes noise. maybe the bearing between seat and mount is not working properly?
    Mount bearing is Monroe Mounting Kit 902953 from Advance Auto.I do not know if it is defective or other problem?
  2. Default
    I searched forums. Maybe the reason is non-Ford strut mounts? Did anyone install Monroe strut mounts without any problem?
    Thanks
    i'll have the same problem, but i hear the squeking noise only when i turn all the way to the right, i just installed the lca's, struts and springs, i went with the camber kit from BATINC, i'll wait for the answer
    "I'm better than great , I'm good" Joey from "Friends"
    born on 04/22/99 # 2002 out of 2760, RS-7 18 inch Enkeis, Dual Magnaflow KYB's + H&R's, Clarion + Kenwood Excelon KFC-X680 6x8"
