Results 1 to 5 of 5
Thread: Lets talk Flanges
    Default Lets talk Flanges
    Ok i just recieved a custom cat-back but i need a 2 bolt flange this one is 3 bolt..So i guess i'll buy a new flex and 2 bolt flange..
    My question is, is there a differece between 2 bolt flanges other than Diameter
    This will need to bolt up to my MSDS y-pipe.
    Ive checked Jegs and Summit..I got kinda lost..Are these all the same or what?..
    Does someone have a link to the proper flange..This will need to be a 3" Diameter.
    Joe
    04 F-150 4x4 loaded Red Magie side exit exhaust, Edge Evolution tuner.
    07 600 ninja was blk now is yellow aka bumble bee, Two bros slip on.
    Want your headlights clear again? PM me for details.
    Aug 2003
    Penfield, NY
    2,675
    If it is a true cat-back it will bolt up after the main cat, which means what flange is on your y-pipe/flex pipe makes no difference.
    The 2-bolt flange does not use a flex pipe. It pivots at the flange and has 2 spring loaded bolts to keep enough pressure on it to keep from leaking.
    The main cat will be different from one to the other though. Your best bet is probably to take your stock exhaust and use the flange off of that.
    Or, shoot some pics of what you have and tell us a little more about what you plan to do.
    00 SVT 0150 - 3.0/HMS/Torsen/Koni The Dark Knight
    99 Cougar - Powered by SVT The White Knight
    Quote Originally Posted by 99Mystique ATX View Post
    Thanks for everyones help..I talked to Tru-bendz todat and there custom making me a piece
    Joe
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Quote Originally Posted by fordman302 View Post
    wow, you actually got someone on the phone
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Yah i left them a voicemail yesterday and they called me back today..
    Joe
