Results 1 to 3 of 3
Thread: SCT Fuel Cut-off Issue Corrected?
    Default SCT Fuel Cut-off Issue Corrected?
    I'm planning on getting a dyno tune after my header install this spring. I read that some time ago (2005), there was an issue w/ SCT tunning in that many people had difficulty raising the fuel cut-off on SFG0/2 programmed SVTs. Has this been corrected in the past 2+ years? Since my car is a SFG2, I will sleep much better knowing that this issue has been corrected
    Also, I tried searching (w/out success) about changing the secondary opening point w/ a SCT tune. Is there a consensus on whether this is possible/beneficial?
    1999 Contour SVT #1966/2760
    Show: Mille Miglia MM-S rims, Stazi mesh, B&M shifter
    Go: Headers, Optimized Y-pipe & TB, Magnaflow res, Mirko MAF adapter + KN-RU3530
    Ride: Koni Kit, SFCs, SS brake lines
    Nov 2000
    Thornhill, Ontario
    1,143
    It was fixed but at the time it was not a part of the mainline programs. It had to be fixed by SCT (Oct/Nov '05 timeline). Generally Tuners and SCT seemed more interested in making their software work on Mustangs and newer cars.
    I wouldn't know if it is fixed in general, but it can be fixed.
    Then: 99 Silver Frost SVT #1919
    237hp/219tq All Motor
    Now: 06 White STI
    Parts 4 sale
    It's funny you mention Mustangs...the place where I'm getting my tune deals w/ Mustangs about 80% of the time. I guess I'll just have to work w/ the shop to make sure the fuel cut-off issue isn't, well, an issue.
