Originally Posted by
GoldnTour
The wiring fix is intended for flickering and dimming. when i was going thorough witht this issue, the voltage was always good around 14~, the fluctuations might be caused by current fluctuations. this mightn not make sense because I=V/R and since load and voltage stay the same it I should not change. the wiring fix is for the ref voltage of the alternator, since the alt puts out an ac signal yopu cannot measure the current output unless you break the circuit. if you cant find loose grounds, just do the wiring fix, its free and it will only take an hour or two.
oh yeah and i had a new alt and new optima red top.
Actually, Crystian, it makes perfect sense. V=IR. If the voltage is constant (as in alternator is working fine and the voltage regulator is working fine), and the resistance is changing (due to a bad or loose reference voltage wire), then the current will change regularly causing the flickering Battery/Charge light.
"Entiendo un poco espaņol"
