Has anybody ever tried running the exhaust out of the front jack point covers?
-You know, like a dodge viper.
Don't think so. I know hector has done side exhausts out of the rear jack covers. Also it's illegal to have exhaust pipes coming out before the doors...or something to that effect.
Chris
1998.5 Black Ford Contour SE 2.5 V6 MTX
1988 Rosso Red Merkur XR4Ti 2.3T I4 AT
It is harmful to performance to run the exhaust out the front jackpoint covers. I would suggest using the rear, as it is the best spot.
Ian
Mine - CDW-27 Zetec ATX | Hers - D186 Vulcan ATX
Aircougar Performance
someone drilled a hole in the side of their rear bumper and ran it out the side of that.. looked kinda cool![]()
TRed CSVT on FSVTs.. 15" in cabin sub.. modified mirko lip.. molded skirts.. this summer's gonna be good
http://www.cardomain.com/ride/2154233
my buddy has done it, exhaust dumps out at the rear drivers side jack point cut out.
I believe he is on the forums too, shoot him a PM if you want pics or some detail on it (I think his screen name is 1fastfucus). I know he has no mufflers and no cats, but i dont know what size tubing he used or anything.
98 T Red SVT-Build # 1147
Some guy on cardomain has pics of it, its been done, it will look like doo doo, but go nuts.
'98.5 2.5L Mystique LS T-Red
'98 SVT E0 BLK/MNB#1663 Port matched 3L
Its been done on several svts and 1 se.
Why do you ask? Do you plan on doing this?
FS:65mm Throttle bodies - SE TB - Zetec TB
Never explain---your friends do not need it and your enemies will not believe you anyway.
I was thinking about it but I probably won't because it costs less to stick with the stock setup.
