Results 1 to 4 of 4
Thread: ok got it fixed but something else is up now.....
    Default ok got it fixed but something else is up now.....
    all i can say is that this is the only ford i shall ever own.....
    ok i just paid $140 for a shop to end up doing what me and my friend did which was swap the fuel pump because it ended up being that the new fuel pump i put in was defective and wasnt working.... so they took it out and i exchanged it and they put it in and it started good but then a couple vacuum lines behind the throttle body were loose so we had to plug them in but there was one line that we couldnt find so idk if it was missing a hose or not.... on the back of the TB it has four different connectors for the hose and there was one on the upper left side (if ur looking down) that was uncovered so we covered it up for now until we find out what the hell was there... but today while i was driving, it was going perfectly and all of a sudden it hesitated... it was stopping and accelerating at the same time while my foot was at the gas..... wtf could be the cause of this..... i also just changed the fuel filter and it keeps on doing it... but its doing it worse now..... can someone please help me out with this and if anything show me a picture of the vacuum connections to the TB
    thanks,
    Robert
    Car- 2007 Star Fire Pearl
    Lexus IS250 6MT
    Old Car: 99 Contour Zetec with PLENTY of Mods...
    Car Club- Myspace.com/HiProfile
    ah dont get me started on the issues ive had with mine. i trump all!!!!!!!! my lastest problem envolved injector harness wires just magically coming out of the connector and the connector just coming apart.
    but i have the same problem possibly. is it happening at part throttle (like 10%)? mine has acted up like i drop throttle then slam it while i just hold it steady. this one has baffled me for a long time. i could only come up with a bad tps for the problem. i have replaced everything else (not to find the problem), and i mean just about everything else like injectors, fuel rail, fpr, iac, maf, some much stuff that its ridiculous how much money ive put in it. ive had all and more the issues then anyone, including replacing the motor.
    im hoping someone may shed some light on this, but the only fix ive found so far, is that i have to give it more throttle to prevent a problem. i do get a stumble sometimes while cruising city speeds, which if the egr is set up like the focus, i know the problem.
    1997 Saturn SL2-project car (salvaged now, current tear down)
    1996 Ford Contour-DD, up and running again
    STC-OH member
    My SL2 and other cars
    Aug 2000
    Bernalillo, NM
    8,460
    Mine does the same thing. Still trying to locate the cause. For now, passing that point on the throttle quickly keeps it from happening.
    -Ken V.
    1998.5 SE Praire Tan Zetec ATX
    Roush springs - Roush sway bar - Bat struts - subframe connectors-Poly here and there - front and rear strut bars - Milli Miglia HT3 17" - SVT bumpers - SE skirts - Striker endlinks - Stazi mesh
    im going to mess with the egr solenoid either today or tomorrow and see if anything good comes from it. possibly, i may have another bad one.
    STC-OH member
