Results 1 to 4 of 4
Thread: wont idle
    Default wont idle
    Okay I parked my car a little over a year ago I was over-reacting (thought it was pecking) I recently started driving it again and now it won't idle. I thought it would reset or something but it is still dying. Is there anything I need to do to get it to reset?
    Jun 2005
    Virginia, USA
    11,070
    Won't idle could be many things. Any CEL codes?
    It could be a massive vacuum loss, bad Idle Air Valve, bad gas, moisture in the gas, etc. Check for broken or leaking hoses in the engine compartment, put a bottle of HEET in the gas tank, and clean or replace the IAC valve. The easiest way to reset the PCM is to remove Fuses 4 and 11 (in the Power Distribution Box next to the battery) for a few minutes.
    "Entiendo un poco espaņol"
    May 2004
    Coon Rapids, MN
    2,873
    Quote Originally Posted by robertseber View Post
    A little over a year ago!
    Is this a SVT, Contour or Mystique (not that it matters to much just curious).
    -Mike
    98 Contour SVT Toreador Red- #49/6535 DOB 3/25/97,178.88whp/157.78ftlbs, Follow my 3L/turbo build here... link
    85 Camaro-1969 350ci, 503BHP
    its a 2000 tour svt
    thanks for the help though
    2000 contour svt mtx
