1979 Trans Am 10th Anniversary Edition
78,000 Original Miles!
1979 10th Anniversary Trans Am
Olds 403 6.6 Litre
Holley 650 cfm Carb.
Edelbrock Performer Intake
Edelbrock Performer-Plus Cam & Lifters
1968 Olds Cutlass 350 Heads
Dynomax Headers with Dual Exhaust
In addition to the above, it has...
-New Belts
-New Timing gears and chain
-New water pump and hoses
-New fuel pump
-New Brake lines
-new radiator
-new fluids all around
Included:
-New set of Richmond 3.73:1 Richmond gears with full Installation kit.
-All original paperwork
-Original spare tire complete with Can-of Air
-New Fender flares and lower spoiler.
-2 extra trunk spoilers and 1 extra set of the side spoilers (that complete the rear spoiler)
-Sunvisors included...not installed
-Both Side mirrors included...not installed
-Door vents are both included...not installed
-new sill plates...not installed
Inside:
It has new re-upholtered seats, new sound deadening, new carpet. The inside is pretty much complete. Only needs new headliner, new rear shelf cover. DASH IS NOT CRACKED!
PROBLEMS
As you can see, the car is not painted. Need a little body work done right behind the doors. Floor pans had some rot up front where the firewall starts, it was cut out and patched. There is also a crack in the windsheild.
Any other questions you can think to ask, I'll answer to the best of my ability.
I am asking for $4,500 FIRM. I bought this car in barely running condition for 3K. Put about $2500-$3,000 into the mechanics of it, and around another $1000 on the interior. That totals 6500-7000, So I believe 4500 is a fair price. She runs strong.
Pics below: *note: the fluids you see under the front of the car are NOT from the Trans Am. I did an engine swap on my other car and the fluids are still in the bucket. The bucket got thrown under my trans am to stay out of the way. THIS CAR DOES NOT LEAK!!
2000 Contour SVT
SF - #542 of 2150
3L: SVT Cams/LIM/UIM/Optimized TB/MAF
HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
Tuning: Xcal2 with PRP
Susp: Bat Euro Kit
