Page 1 of 4
1 2 3 ... LastLast
Results 1 to 10 of 35
Thread: best pedals?
  1. Cool best pedals?
    whos got the best pedals on their csvt
    Dec 2001
    Enfield, CT
    21,507
    Blog Entries
    93
    what are you going for, grip or show?
    for grip just get the autozone special ...
    http://www.fordcontour.org/index.php...ID=867&CID=163
    if you want show go with autovation, but they are slippery when wet, otherwise grip great
    http://www.fordcontour.org/index.php...ID=619&CID=121
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport
    - 2k Contour SVT - #2137
    Aircougar Performance
  3. Default
    for the autozone ones.. how did you mod the gas pedal.. did you use longer bolts?
    Dec 2001
    Enfield, CT
    21,507
    Blog Entries
    93
    Quote Originally Posted by 99csvtraw View Post
    bought the car that way so i don't know how they where put on other then the previous owner made his own mounting brakets to make the pedals very secure as I guess they have a tendency to move around if installed how they come
  5. Default
    kinda off subject but i need your opinion.. my heater control.. it only works on high and not the other speeds.. what do yah think might be the cause of that
    Dec 2003
    New Haven, CT
    3,040
    I think you would get better answers starting a new thread in troubleshooting.
    Chris
    1998.5 Black Ford Contour SE 2.5 V6 MTX
    1988 Rosso Red Merkur XR4Ti 2.3T I4 AT
    Dec 2001
    Enfield, CT
    21,507
    Blog Entries
    93
    Quote Originally Posted by hotdimmes View Post
    best idea but also a search will turn up that answer too
    the gas pedal is plastic or hardened rubber so what i did was drill right through the middle of the pedal. 2 holes using the pedal cover as a guide.
    IMHO, the clutch cover will eventually start twisting and eventually end up where mine is ............in the back seat somewhere!
    autozone did have a set that didn't have the foldable clamps but actually came in a 2 pc set where you simply screw the pedal cover to a underside brace but i haven't seen them lately. when i do, i will make the switch!!
    oh...you gotta be carefull too. I wear timberland boots which can be a little wider than avg, so be sure that you allow yourself enough room btwn the brake cover and accelerator pedal. safety reasons of course.
    personally, i advise spending the the extra bucks for a nice set vs the $12.99 at auto zone
    1998.5 Silfro CSVT #6418
    2004 Merc Marauder
    **reddired - (ready red)
  9. Default
    yeah thats true.. i got the autozone ones and i kno what your talking about having some room between the acc. n brake.. im gonna have try to move the brake pedal over towards the clutch.
    and i have to mod the accel. pedal cause the damn thing is think plastic.
  10. #10
    I have a set of the cheap pedals... they're still aluminum though, for an MTX. Real cheap; PM me if you want them.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX (for sale, see classifieds)
