Results 1 to 7 of 7
Thread: adding stock fog lights
    Default adding stock fog lights
    what is needed to add the stock headlights to a pre-98 without?
    '72 mercedes 280SE 2.8 I6
    '01 crown vic 4.6L P72 Ford Blue
    '97 'tour GL 2.0 SOLD
    want to buy pre 98s in MN
    Jun 2000
    Hammertown, Canada
    611
    First thing you'll need is the front bumper cover c/w nacelles....
    96 SE with '01 3.0. Overbored 62mm throttle body, custom LIM, double honed SVT UIM, SVT cams, headers, custom Y pipe, custom mandrel bent SS 2.5" exhaust, Quaife, torque brace and custom frt & rr suspension.
    I make custom suspension parts.
    Mar 2004
    Louisivlle Ky
    5,190
    Quote Originally Posted by Bradness View Post
    pre98 has a plastic piece that is bolted in to fill the fog light holes. no need to change bumpers.
    first thing you should do is check to see if your car already has the factory wiring harness for the fog lights. some contours came with everything except the fog lights w/brackets, headlight switch, and relay. if your lucky yours is one of those. if not then you will need all those parts as well as the factory wiring harness.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
    it looks like I have a lot of extra wires behind the dash, I think I might be set on the harness, but how can I be sure what to look for? I tried to look behind the bumper for wiring but couldn't get a real good look. I'm going to do a search, but it would be great if I could get some pics.
    You don't have to use the stock wiring set-up. You could just wire it up from the battery. I have mine set-up with a relay so they come on with the headlights.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX (for sale, see classifieds)
    Dec 2003
    New Haven, CT
    2,998
    Quote Originally Posted by Matt R View Post
    +1, I have mine setup from the battery with a relay so they come on an off with the car (pending the out of sight switch underneath the steering column is on.) That way I never forget to leave them on when I turn the car off. And I Can drive around all cool with just fogs on
    Chris
    1998.5 Black Ford Contour SE 2.5 V6 MTX
    1988 Rosso Red Merkur XR4Ti 2.3T I4 AT
    Mar 2004
    Louisivlle Ky
    5,190
    Quote Originally Posted by hotdimmes View Post
    +1 as well, although mine are relayed off the corner lights so it looks like i have the fog light mod done
    '00 Black SVTC #391
    Now For Sale
