Page 1 of 2
1 2 LastLast
Results 1 to 10 of 20
Thread: Supercharger Question.
    Default Supercharger Question.
    I have a pre '98 AWD Ford Mondeo Estate which i'm in the process of modifying. I'm looking at modifying the engine and want to go for a supercharger however I don't like to go on the normal route. Bit of an awkward sod me!!
    The T'box in the AWD I have been informed can take anywhere between 250-300bhp so I want to squeeze as much torque as i can out of the little 4pot. Ideally i'd like to get a stroker kit if such a thing is made or possible. Also I know I could buy a Jackson Racing kit but that's limited to at best 8psi and if i'm correct uses the stock Inlet Manifold. The stock manifold is a very limiting factor as can be seen when you add throttle bodies which, even on a naturally aspirated engine can unleash over 20bhp. I was looking at using a Centrifugal Supercharger such as one supplied by Vortech, throttle bodies + all the necessary electrical kit that goes with it and fitting an Intercooler, the likes of a Saab 9000 as with minimal mods it'll fit comfortably.
    Tell me though, can anyone tell me what are the pro's + cons of using centrifugal blowers over roots and other types of blowers? With a centrifugal type I can run higher boost and get bigger torque but has anyone any idea what psi roughly i'd have to run to get up to 300bhp. She will obviously get headwork + cams, custom induction kit etc to up the power naturally first. I'm looking for as instant power as I can get to get the big Estate moving quick, especially with AWD?
    All answers welcomed.
    the jackson racing bbk is about 8psi and you can gain a few more psi with an 5.7" od pulley, this will just about max out the blower. as there is no intercooler you will definately need wmi to coll down iats. the focus boys seem to think 200 whp is about the limit from this kit on the zetec.
    the jrsc uses its own intake manifold to which the compressor sits on top.
    see pics.
    if you take a look on focaljet there are some zetec foci using centrifugal blowers and there is a wealth of information too.
    Blown by Jackson Racing
    203 hp / 178tq
    Jul 2007
    Middletown, Pa
    1,902
    do u think the SC was worth the cost? and how hard was it to install. also, this may sound dumb, but from what u were saying, what does wmi and iats stand for?
    00 Contour SVT #1914 BLK/PT 3L Hybid, Torsen, MSDS.
    00 Contour SVT #0157 BLK/PT stripped down and parting out (15.2 @ 89, 195whp)
    95 Mystique GS:16.989@ 82.02 MPH, 38.7MPG's RIP
    Mar 2004
    Louisivlle Ky
    6,934
    Quote Originally Posted by 95_Mystique View Post
    WMI=water/methanol injection (IIRC)
    IATs=Intake air temp's
    and yes FI on a zetec makes a HUGE difference.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Aug 2001
    Villa Park, IL
    19,625
    Yes it was worth it EVEN with the ATX.
    2008 Mazdaspeed3 Sport "The Angry Goose"
    2000 SUPERCHARGED Ford Contour Zetec- sold 10/20/05
    "He's not the Stig, but the Stig's Mexican cousin!"
    Jul 2007
    Middletown, Pa
    1,902
    is it possible to do on a 95 car, cuz they are all OBD-1 computer hookups...
    as said above its worth doing. it was pretty straight forward to install on my 2000 (blacktop) mondeo. i had to get a focus alternator because the mondeo one was a bit bigger and the bracket fouled the inlet manifold. i also had to change the idle control valve to a focus one as the electric plug on the mondeo one came out at 90 degrees and fouled the bypass valve on the sc. a focus one is straight.
    i had to modify a bracket that fits beneath the inlet manifold and supports the whole thing.
    i also fitted a focus central 65mm throttle body and needed to fit a focus throttle cable bracket.
    then i had an after market chip fitted and a custom tune as the jackson racing reflash of the stock ecu wasnt any good to me in the uk.
    a buddy of mine has a pre 98 mondeo (mk1) with the silvertop motor and has a jackson racing sc on his but it needed some more modding to fit. i believe he had a spacer fabbed to fit between the sc and the inlet manifold and an alteration to the alternator bracketry.
    he to has an aftermarket chip and a custom tune.
    203 hp / 178tq
    Aug 2002
    Southeast WI
    1,715
    I'd really love to see pics of your buddy's pre-98 setup. Maybe something that I haven't thought of. The biggest roadblock to putting a JRSC on a pre-98 is the idler pulley and alternator mounting.
    Thanks,
    BP
    --'96 GL * MTX Zetec-- SOLD! 3-12-2011
    --- '06 Mazda 6s * 3L Duratec * 6-speed ATX * Lapis Blue ---
    FOR SALE >> T3 Super 60 Turbo - Coated Focus Manifold - 42# FRPP Injectors - Focus CFM Throttle Body << FOR SALE (PM me)
  9. #9
    Quote Originally Posted by ButtonPuncher View Post
    Thanks,
    BP
    he is a member on here, you may know him user name percybigun.
    found a pic and a vid on my pc.
    here is a link to his website with info about his mods.. http://members.lycos.co.uk/plandesigns/mk1index.htm
    edit.. found another pic
    203 hp / 178tq
  10. #10
    Aug 2002
    Southeast WI
    1,715
    WOW I'm getting forgetful. That's right, Percy did have a Pre-98. But I thing he was using a small honda alternator or something.
    BP
Page 1 of 2
1 2 LastLast
