Page 1 of 6
1 2 3 ... LastLast
Results 1 to 10 of 51
Thread: resonator delete
    Default resonator delete
    does anybody have any knowledge on resonator deletes? like if hurts the car in any way? if there are any other problems associated with this kind of mod??
    needing help soon!!!
    Matt
    1998 silver SVT Contour
    Shawnee, KS
    Quote Originally Posted by 98silverCSVT View Post
    Have it cut out, and put a piece of straight pipe there, no ill effects at all!
    what kind of cost goes into installing a straight pipe in for the resonator?
    Matt
    Shawnee, KS
    if the shop charges more then 40 bucks, take is elsewhere!
    Apr 2005
    Pillaging in Freedom, PA.
    3,873
    Many say that a straight pipe will lead to rasp, you can also replace the factory resonator with a muffler with a 2.25" diameter, straight through design. I personally used a glasspack instead, others prefer a magnaflow. Check out the exhaust clips thread to get your own opinion.
    Scott,
    1999 CSVT, Tropic Green, #2068
    "And that was all without even a single drop of rum" -Captain Jack Sparrow.
    If I'm a moderator, why don't I have groupies!?!
    Nov 2006
    oneonta,ny
    2,393
    20 dollar glass pack FTMFW!!!
    getsum111 is right on the rasp. i personally suggest cutting the res, replacing with a straight pipe then adding a magnaflo (M-11114)
    good sound and not ricey at all.
    Quote Originally Posted by getsum111 View Post
    1998.5 Silfro CSVT #6418
    2004 Merc Marauder
    **reddired - (ready red)
    Apr 2005
    3,873
    Quote Originally Posted by 95pgt-t View Post
    You'll be able to hear it at Carlisle if you're going.
    Scott,
  9. #9
    I did the Resonator delete and put in a 2.25" midpipe. Sounds good but beware your y-pipe or flex pipe might break...Mine did and it flutters and sounds poopy.
    1998.5 CSVT #475
    Former car : 2001 Mazda MP3 #474
    ???? Interesting!
  10. #10
    Nov 2006
    oneonta,ny
    2,393
    i'm going to carlisle,and i've heard them before. i sold mine to christine for her daughter
