Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 22
Thread: High tower help
    Jun 2006
    Hampstead, Maryland
    1,258
    Question High tower help
    im plan on doing this mod this saturday and want to go with a flat black on a silver frost car. my questions are as follows.
    What grit of sand paper should i use to remove the chrome?
    Should i prime it gray?
    any specail tipe of oblack paint i should use or would duplicolor type paint(rattle can) work fine?
    where can i find the high temp silicone RTV at?
    Should i clear coat the black or leave it flat?
    Thanks
    2001 Ford SVT F150 Lightning Black
    1998 Ford SVT Contour Silver Frost E0 #3455/6535 *sold*
    *lots of contour parts for sale please PM me*
    http://www.contour.org/ceg-vb/showthread.php?t=31994
    Quote Originally Posted by my98SVTturbo View Post
    Thanks
    You can wipe the chrome right off with never Dull or Mothers..I tryed this and took forever..And you can even bust threw if you go to long in one area..If i were you get some 600gritt sand paper scuff it all Base it whatever color you choose..And let dry
    and then clear it..Depending on what you want it to come out like..I like a glossy black and clear..
    You can get the RTV from your Autozone or Advanced auto etc.
    Joe
    04 F-150 4x4 loaded Red Magie side exit exhaust, Edge Evolution tuner.
    07 600 ninja was blk now is yellow aka bumble bee, Two bros slip on.
    Want your headlights clear again? PM me for details.
    Apr 2006
    Fort Myers, FL
    4,096
    i just scuffed up the chrome real good, two coats of primer, 6 coats of black, 3 coats of clear
    98 SVT E0 Black/MNB #1756
    98 SVT E1 Silfro/MNB #4852
    Nov 2006
    oneonta,ny
    2,393
    i didnt even get that carried away,i used 400 grit to scuff it,and used three coats of gloss black,two coats of clear coat. they arent exposed to road debris so they dont need to be ubber thick w/paint and clear
    Quote Originally Posted by 95pgt-t View Post
    Primer is a Sealant to seal the item..And Shawns 6 coats of black could be Even light coats..Your 3 coats could have been even heavier coats..
    Heck my old Hightowers i put like 4 heaven coats on and no clear or primer..
    Its all on how much Quality you are looking for..
    Joe
    Jun 2006
    Hampstead, Maryland
    1,258
    Quote Originally Posted by fordman302 View Post
    lookin for the best quality
    Best quality-
    After removing the chrome insert remove the orange corner lense..
    scuff with a 400gritt
    Blow off with air, Primer till all is coveed should be a good 2 coats
    scuff again with 400gritt apply another 2 coats of primer cover all..
    Wet sand with 600gritt till its smooth if you bust threw go back and repeat your previous steps.
    Use adhesive promter then base it with your color..Alow to dry then Clear coat it..
    If you have any other Questions just ask.
    Joe
    Nov 2006
    oneonta,ny
    2,393
    and wear rubber gloves to keep your oily paws off of the paint
  9. #9
    Yes and also get a Wax and Grease remover to wipe down after your done baseing to remove any silicone/grease and oil..and make sure all wet sand residue is remove.
    Joe
  10. #10
    Jun 2006
    Hampstead, Maryland
    1,258
    whats adhesive promter?
    and would gloss black krylon fusion plastic paint be good for this?
    and also how many coats of paint? (6 light coats per light?)
