What's the min and max operating temperature for the Duratec V6?
Curtis
3L 'Oval Port' 98 Black SVT
180.5HP/178lbft
'03 Black Sport Trac
depends on the thermostat ... stock is 190
so it runs 190 to 212 ...
My question was more basic than that as I'm interested in the min and max operating temps of the engine.
Curtis
180.5HP/178lbft
not sure exactly what you are trying to get a then ... if the car starts and runs in that temp then it runs ... or are you asking for the complete range of temps that the coolant can see ...![]()
the other winter here in CT we had that two week period where it was about zero to 13 degrees overnight ... cars started every morning in those temps
My svt runs around 180-190.Max that it has gotten to was 230.It wont hurt it but not good.Was running the car hard and down here in FL it can get pretty hot.
Joe
04 F-150 4x4 loaded Red Magie side exit exhaust, Edge Evolution tuner.
07 600 ninja was blk now is yellow aka bumble bee, Two bros slip on.
Want your headlights clear again? PM me for details.
At what tempeture does the duratec V6 overheat? At what temp would the duratec V6 be considered warmed up after a cold start?
Curtis
180.5HP/178lbft
With a 190 t-stat, fan on at 212 off at 198. Consider it warmed up enough to stomp on at and above 160 F ONLY if you have a high quality synmthetic oil like Amsoil 0W-30. Its oil related not car related. The additive packages are designed to work best above those temps. Stan
