Page 1 of 2
1 2 LastLast
Results 1 to 10 of 19
Thread: Exaust
    Default Exaust
    Saturday I through my car up on the lift and gave it a full inspection. I found my muffler is starting to rust out on me and that got me thinking about what I should do. I'm already planning to cut out the resonator (2.25in pipe correct?) and now I'm thinking about just cutting out the muffler too.
    What kind of effect would it have on the car with so little back pressure?
    Also I live in michigan so I don't have to worry about emissions tests or anything so I was thinking about cutting the cat out too. Opinions?
    Aug 2001
    Villa Park, IL
    19,625
    2.25" with either a resonator under the car OR a muffler at the end.
    2008 Mazdaspeed3 Sport "The Angry Goose"
    2000 SUPERCHARGED Ford Contour Zetec- sold 10/20/05
    "He's not the Stig, but the Stig's Mexican cousin!"
    Mar 2004
    Louisivlle Ky
    6,934
    I wouldnt worry about too little back pressure. i was running with 2.5" cat back on the zetec before the turbo and i got a nice power gain out of it.
    IMO you can run either 2.25" OR 2.5", whatever is cheaper and easier for you will work well. also, i agree with Hector about only using EITHER a resonator OR a muffler.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Well what would be my best route?
    The muffler has a few holes in the bottom, and the resonator looks clean. Would it be that bad of an idea to just cut both out?
    Mar 2004
    Louisivlle Ky
    6,934
    Quote Originally Posted by KennyT772 View Post
    i would get the whole system from the flex pipe back replaced with either 2.25" or 2.5" piping and add a resonator or a muffler.
    Sep 2007
    Delaware
    540
    Quote Originally Posted by striker2 View Post
    That's what i did and it sounds delicious imo.
    There's a little extra pep in the high end too.
    How much would a complete exhaust setup cost with a nice muffler? If I put the money into it I would probably go with a dual instead of the single.
    Sep 2004
    Tampa, FL
    2,095
    You may be able to find an SVT exhaust someone is selling. You live in MI, so I'm sure you can find someone local too. This is if you want to go dual. Cut out the res or the mufflers for a great sounding zetec.
    1995 Contour GL, Zetec, ATX, 118k - Sold
    2012 Mitsubishi Lancer GT, 2.4L, CVT and it begins again.
  9. #9
    I'm thinking I'll get my hands on a SVT and cut the res. Right now the drivers side fender motor mount is top priority, then once I get some cash the exhaust is next. Eventually I would like to swap the atx for a manual...
  10. #10
    Mar 2007
    South Amherst, MA
    6,054
    Blog Entries
    7
    The SVT exhaust on the Zetec is tricky. You can't really install the whole entire thing, because on the Duratec, the main is located where our flex pipe is, so the best you can do is go from flange-back...kind of. The flange on the Duratec is farther back than on the Zetec. If you want I can snap a pic of the underside of my car tomorrow.
    Ian
    2012 Hyundai Accent hatchback
    1996 Zetec ATX - Retired but still running (barely)
    Aircougar Performance
Page 1 of 2
1 2 LastLast
