Page 1 of 4
1 2 3 ... LastLast
Results 1 to 10 of 36
Thread: Focus manifold
    Aug 2000
    Bernalillo, NM
    8,452
    Default Focus manifold
    Picked this up in a junkyard off a Focus for cheap. Think its worth installing? To me it seems like it would breathe better than my stock mani. Cat flange is different, but if I put this on, I would spring for an aftermarket cat anyway. I have never seen this type of manifold before, then again I've never really paid attention
    -Ken V.
    1998.5 SE Praire Tan Zetec ATX
    Roush springs - Roush sway bar - Bat struts - subframe connectors-Poly here and there - front and rear strut bars - Milli Miglia HT3 17" - SVT bumpers - SE skirts - Striker endlinks - Stazi mesh
    I'm not sure that it would match the bolt pattern but it might. The quickest way to find out is buy a gasket for your car and see if it lines up with that manifold. Now I'm almost certain that for the time and expense you will eat up making this fit and work well you would have been better off buying a header. Go look at the location of your 02 sensors and understand that you will need to find a place to re-locate them. You probably will have to fab a straight pipe of some distance between that flange and the new cat. That's where you will need to put the first one.
    That all being said I am all for trying wierd and different things.
    Aug 2000
    Bernalillo, NM
    8,452
    Quote Originally Posted by DESIGN View Post
    Same here, and I love cheap mods, which is why Im thinking about trying this manifold.
    There was a Contour next to the Focus, I was able to test fit all I needed to. It will psysically bolt up, and there is plenty of room, I even got the heatshield for it. As far as fabricating the rest of the exhaust goes, thats the part I enjoy more than the finished product, so all the time spent on it will be fun. I think I can have a finished product for less than $50 total, not including a high flow cat.
    Im just going to try it, and if it sucks, I can just go back to stock but still use the new cat.
    -Ken V.
    Nov 2005
    Rittman, OH, USA
    151
    I was curious about doing the same, and looked into it. On the foci the EGR is in the cat, not the header like on the tours. I would imagine, if you got the cat with it, you could sawp the whole thing, then figure some custom flange for the rest. I'm not sure if the bolt pattern is the same or not, or even if my idea will even work. That was my intent, to get a full focus exhaust, and hope the header bolts match.
    Lemme know how it goes if you try it.
    Aug 2002
    Southeast WI
    1,715
    It definitely won't fit...
    ...don't worry guys. It will bolt right up to the block. (This pic is with the header on my new '96 Zetec.)
    The problem that you will run into trying to run a full Focus exhaust is the the Contour/Mystiques' oilpan is completely different. The Focus has a shallow pan with a tunnel for the exhaust. We don't.
    You are best off having and exhaust shop make you a custom downpipe with the proper O2 fittings. You could then put a high-flow cat where the Mondeo Zetecs have them....under the car.
    Look under your 'tour. Notice that big-ass heat shield just past the flange that connects to the flex pipe? Perfect place for a high-flow cat.
    HTH,
    BP
    --'96 GL * MTX Zetec-- SOLD! 3-12-2011
    --- '06 Mazda 6s * 3L Duratec * 6-speed ATX * Lapis Blue ---
    FOR SALE >> T3 Super 60 Turbo - Coated Focus Manifold - 42# FRPP Injectors - Focus CFM Throttle Body << FOR SALE (PM me)
    Nov 2005
    Rittman, OH, USA
    151
    Can you use the stock gasket, or do you have to grab the focus one?
    Aug 2001
    Villa Park, IL
    19,625
    Quote Originally Posted by tedBalog View Post
    Just buy a new one. I bought a new copper exhaust mani gasket for about $10.
    2008 Mazdaspeed3 Sport "The Angry Goose"
    2000 SUPERCHARGED Ford Contour Zetec- sold 10/20/05
    "He's not the Stig, but the Stig's Mexican cousin!"
    Aug 2000
    Bernalillo, NM
    8,452
    Quote Originally Posted by ButtonPuncher View Post
    HTH,
    BP
    Guess Im not the first person to look at this manifold as a possible swap Looks good. Will moving the cat that far back affect a emissions inspection visually? I thought it had to stay in the stock location.
    My plan is to weld a small (about 2-3" piece of pipe) between the mani and cat. My O2 sensor will go there. Then make my own 90 degree bend to take the rest of the exhaust in the stock location. That stock 90 degree bend looks really bad for flow anyway. It looks almost crimped.
    After cruising through the Focus boards looking at different manifolds, I learned about the early 2000 Focus intake manifold and that its supposedly good for 5-7 HP over any other stock piece. Might try to get it this weekend after I do a little more research. There is one at the yard I got the exhuast manifold from.
    -Ken V.
  9. #9
    Jul 2004
    Trinidad
    91
    You may want to rethink the intake manifold swap... the contour intake manifold is almost the same as the good focus one.
    1997 Mondeo Ghia 2.0 ATX
  10. #10
    Jul 2004
    Trinidad
    91
    Check the old forum for some details.... cant remember the exact thread
Page 1 of 4
1 2 3 ... LastLast
