Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: Wideband Location Question for the Experts
    Default Wideband Location Question for the Experts
    I'm looking to add in a wideband o2 Sensor and controller. I'm trying to get a members feedback to a question.
    Can I replace one of my narrow band o2 sensors (possibly the downstream ones) with a wideband. Many of the systems come with narrowband output. The seem to imply that I can direct the narrowband signal to the engine control system
    I'm really trying to avoid having to weld in a new bung. If I have to, can anyone tell me where they've installed their wideband? I'd like to use a suitable location already chosen by a member who's had success!
    Thanks,
    Pete
    PowerDyne BD-11a waiting to be dyno'd
  2. Default
    Yes you can use a downstream o2 bung, but will need to have a tune to eliminate the CEL you will get from disconnecting your narrow band
    US23
    Feb 2006
    Southeast Michigan
    2,997
    Gut your precats to get a more accurate a/f wideband read. Unless you have headers?
    98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
    Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
    PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
    Dec 2001
    Enfield, CT
    20,510
    Blog Entries
    93
    when I got my test pipe I had a bung installed infront of the high flow cat for my wideband sensor and controller, when ever I get that installed ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    I asked Trubendz to put the bung in, but they put it in after the cat, so I plugged it up, took it to a welder, and had him tig(stainless steel) a new bung in before the cat.
    Black 1998.5 LX
    3.0L Split Port Conversion
    HMS Transmission
    Lots of other stuff
    Ressurected 06/14/06
    I put my wideband O2 bung on my truebendz y-pipe right before the flexpipe where both pipes come together.
    Death is Certain, Life is Not
    R.I.P. Dad
    Kevin Joseph Trundle
    1959-2008
    1999 Contour SVT Toreador Red/Prairie Tan Build #1592/2760
    1991 F-150 Nite Edition 4x4
    2004 Honda CBR1000RR
    Quote Originally Posted by Red99CSVT View Post
    I believe mine is at the same spot.
    1998 #5979 SF/MNB
    2000 #0801 B/T
    BUY MY STUFF IN THE CLASSIFIEDS!!!!!
    Dec 2001
    Enfield, CT
    20,510
    Blog Entries
    93
    Quote Originally Posted by muntus View Post
    what they did for me when I asked was they took their standard test pipe with high flow cat and bung after the car for the cougar and flipped the flanges, so instead of the car being right at the y-pipe then having pipe run to the exhaust the cat is closer to the exhaust. I was kinda ticked off at first they did it that way but it fit correctly.
    - 95 Mystique LS
  9. #9
    Yeah, I thought I was pretty clear when I ordered mine, but they did it their way. Oh well. It was easier to pay a welder to do it(he taught me some tig welding tricks at the same time ). It did fit correctly.
    Black 1998.5 LX
    HMS Transmission
    Lots of other stuff
  10. #10
    Default Alright!
    Quote Originally Posted by Pudmunkie View Post
    Thanks for this, I'll talk to my mechanic, and if the weld in is a quick and easy, then I'll do that. However, if it's a problem to do it, then I'll just get brenspeed to complete a tune, they are awesome!!!!
    Thanks pud
