ive searched and i cant find an exact answer to this. Does the 2000 contour have an iac valve and where is it located if there is one. Pics or diagrams would be nice.
Yes, access from below the car. It is next to the starter. Haynes has a picture.
Location of the IAC for the Zetec.
"It's on the back side of the intake plenum under the throttle body area." DESIGN.
I looked at the Haynes manual and the Zetec IAC valve is located next to the starter. Below are the steps from the 1996 Ford CD to remove it .
Idle Air Control (IAC) Valve
Removal
1. Disconnect battery ground cable
2. Remove the air cleaner outlet tube and resonator assembly.
3. Disconnect the main chassis vacuum line.
4. Disconnect the ignition coil and radio interference capacitor wiring.
5. Remove the fuel line bracket retaining bolt.
6. On 2.0L engine equipped vehicles, raise vehicle on hoist.
7.
7. Disconnect the engine control sensor wiring or fuel charging wiring (depending upon application) from the idle air control valve (IAC valve) at the idle air control valve connector.
8. On 2.5L engine equipped vehicles, remove retainer for engine control sensor wiring from the upper retaining stud bolt.
9. Remove the two idle air control valve retaining bolts or stud bolt (depending upon application).
10. Remove the idle air control valve and idle air control valve gasket.
Installation
1. Note: If scraping is necessary, be careful not to damage idle air control valve or intake manifold idle air control valve gasket surfaces or drop material into intake manifold.
Clean idle air control valve gasket mating surfaces.
2. To install idle air control valve, reverse Removal procedure. Tighten the fuel line bracket bolt to 8-12 N-m (71-106 lb-in).
3. On 2.5L engine equipped vehicles, tighten the retaining bolt and stud bolt to 8-12
4. On 2.0L engine equipped vehicles, tighten the idle air control valve retaining bolts to 8-11 N-m (71-97 lb-in).
I have removed it on my pre98 and as far as I know the 2000 its in the same location, be prepared to have to go underneath the car to get it, its in the most annoying location ever.
Sold the CSVT, replaced it with a Screaming Yellow 2003 EAP SVT Focus
Strange, it only took me a few minutes to change mine from the top.
-Ken V.
1998.5 SE Praire Tan Zetec ATX
Roush springs - Roush sway bar - Bat struts - subframe connectors-Poly here and there - front and rear strut bars - Milli Miglia HT3 17" - SVT bumpers - SE skirts - Striker endlinks - Stazi mesh
heres a pic of my iac valve, (2 ltr mondeo) its located on the inlet manifold below the tb, two 8mm bolts hold it on.if you replace it you will need two rubber gaskets too.
Blown by Jackson Racing
203 hp / 178tq
