Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: Bosch O2 part numbers
    Nov 2002
    Connecticut
    311
    Default Bosch O2 part numbers
    I'm looking for the precat O2's on my 99 SVT (built post 1/2/99). The posts I found on CEG almost always refer to Bosch 13115 as the precat O2 (one post showed 15717).
    I found the following Bosch O2 part numbers on boschauto.com. All refer to SVT's. (note: model year 1999 are split by build date as "to 1/2/99" and "1/2/99 on").
    In additon to the chart below, I called Autozone to check stock and they said it is part number 15718!
    Year PreCat PostCat
    2000 15716 15717
    to99 15717 13133
    99on 15717 15717
    1998 13115 13133
    Does anyone know the differences between 15716, 15717, 15718, and 13115? More importantly, any recommondations on what to use (precats only)?
    '99 Silver CSVT
    '07 Harley Street Bob
    '78 Winnebago Minnie Winnie (Dodge Chassis 23', 440cid, 4bbl)
    Dec 2001
    Gales Ferry, CT
    24,502
    Blog Entries
    93
    hmm interesting, parts america.com list both the upstream and down stream sensor as 15718 and 15717
    just remember that upstream sensors have square connectors and the downstream sensors have round ones ...
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Dec 2004
    Utah
    1,124
    What about post cats?
    Black 1998.5 LX
    3.0L Split Port Conversion
    HMS Transmission
    Lots of other stuff
    Ressurected 06/14/06
    Nov 2002
    Connecticut
    311
    ...the upstream sensors have square connectors and the downstream sensors have round ones ...
    BrApple - I got impatient and bought the 15717's recommended by Autozone/Pep Boys. Unfortunately they have the round connectors Is the upstream=square and downstream=round true for all year of SVT's?
    Muntus - I am not concerned about the downstream sensors because I will use MIL eliminators if necessary. My understanding is that they do not affect performance, and MIL eliminators are cheaper than O2's or new precats.
    '99 Silver CSVT
    Dec 2004
    Utah
    1,124
    Quote Originally Posted by SVT_CT View Post
    muntus - I am not concerned about the downstream sensors because I will use MIL eliminators if necessary. My understanding is that they do not affect performance, and MIL eliminators are cheaper than O2's or new precats.
    My downstream o2 sensor(the round connector type) is bad. I have the WeaponR headers and when I put in my 3L with the o2 sensor in the header, it got damaged as it hit something going in. The MIL eliminators I made from Radio Shack parts worked great, but they don't do the job if the sensor is bad.
    Stupid Salt Lake County has emissions testing(Utah varies from county to county for emissions). I have to fix it before my temporary permit expires.
    I'm just going to get a new sensor(the round kind), get new Radio Shack parts, and solder it up.
    Black 1998.5 LX
    HMS Transmission
    Lots of other stuff
    Nov 2002
    Connecticut
    311
    So the MIL eliminators need a good sensor to work? I always thought the cap/resistor did the trick and the sensor was left in just to fill in the bung hole
    (I just had to say it that way)
    '99 Silver CSVT
    Dec 2004
    Utah
    1,124
    Quote Originally Posted by projectSHO89 View Post
    The MIL eliminator circuit is NOT part of the heater circuit, which is what the P0161 fault code points to. The heater circuit must be intact regardless of whether a MIL eliminator circuit is installed or not.
    If the sensor is broken, eliminators will not fix them, bunghole.
    Black 1998.5 LX
    HMS Transmission
    Lots of other stuff
    Sep 2000
    7,295
    The MIL eliminators modify the signal to make the computer believe that the cat is properly functioning. They need a signal to function.
    The way the cat monitor works is that the computer compares the switching speed of the upstream sensor to the switching speed of the downstream sensor. The cat monitor runs occasionally, not all the time. It runs after several conditions have been met, including the the engine is warmed up and stabilized. The sensors fluctuate with the exhaust pulse as the exhaust valves open and close. The switching is very rapid. If the cat is working properly, the switching will be much slower downstream of the cat. In our case, it only monitors the pre-cats. When the downstream switching rate too closely mirrors the upstream sensor, the cat monitor says "tilt" and turns on the MIL (malfunction indicator light aka CEL or check engine light). It also sets a code.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
  9. #9
    Jul 2006
    Asheville NC
    295
    i have downstream o2s for sale in classifieds cheap
    brand new!!!!!!!!!!!!!!!!!
    Quote Originally Posted by ChattavegasSE View Post
    I carry all my money in a mattress.
  10. #10
    Dec 2004
    Utah
    1,124
    Quote Originally Posted by drivebymashing View Post
    Too bad my temporary permit expires in a few days.
    Black 1998.5 LX
    HMS Transmission
    Lots of other stuff
Page 1 of 2
1 2 LastLast
