I've got about $1,000 in it so far and about another $500+ to go on just finishing the motor itself. Then figure another $1000 for rebuilding the transmission and getting a new flywheel and clutch.
Money spent so far includes:
3.0 - $500
Gas to go get new motor - ~$100
Engine hoist and stand - ~$300
Junkyard parts and new tools - $100 - $200
Things left to get just for the motor
Serpentine Belt
Waterpump belt
Waterpump gasket
160F Thermostat
Coolant temp sensor
Coolant temp sender
Cam sensor
EGR Valve
EGR valve gasket
O2 sensors
Crankshaft sensor
UIM/LIM gasket
Fuel pressure regulator
fuel injector O rings
Spark plugs
Plug wires
TTY crank bolt
2.5L oil pick-up tube
2.5 oil dip stick
Idler pulley
Pulley tensioner
Timing cover gasket
Crank seal
Former - 98 CSVT E0 T-Red 4/4/97 #173 of 6535
4 out of 3 people have problems with fractions.
98 SVT Contour #2 98 SVT Contour #587 99 SVT Contour #1256
