I have a 98 SVT with approx 100k on it. I started noticing a slight lifter tick a few months ago. Now it seems to be getting worse. I have never over-reved the car either.
My question: Is there anything that I can do about this?
97 procharged Cobra
09 Buell 1125R
Former owner of:
#9 #135 #1119 #4427 3l SeVT
Aircougar Performance
Try a bottle of Engine Restorer. For $5, you can't go wrong.
In addition, just before changing the oil, pour a bottle of Seafoam in the engine, then run it for 15 minutes or so, then change the oil and filter. Sometimes, this helps if it is dirty valves, etc.
"Entiendo un poco espaņol"
I had the same problem.But i got the lifter tick from over reving a new motor.Take some time if your handy and pull the upper intake off and the valve covers..Its pretty self simple.And take a look and let me know what you see if anything looks out of place.I notice my lifter wasnt even in place..Hope this helps some.
Joe
04 F-150 4x4 loaded Red Magie side exit exhaust, Edge Evolution tuner.
07 600 ninja was blk now is yellow aka bumble bee, Two bros slip on.
Want your headlights clear again? PM me for details.
If it is out of place... what do I do from there?
97 procharged Cobra
09 Buell 1125R
Former owner of:
I ordered a brand new lifter and rocker.After it was ticking i shot it straight threw the valve cover.But yes if out of place you can try to put it back in place.Move it around and if theres any play, Replace it dont drive it like that.You will hurt it more.Cheap parts i think i spent less that 20 bucks on the lifter and rocker.Keep me updated.
Joe
Can the lifter and rocker be replaced with just the valve cover off? And is it easy?
97 procharged Cobra
09 Buell 1125R
Former owner of:
Yes just with the vavle cover off..Its fairly easy..The spring need to pushed to replace the rocker(Need to get it under the cam).Its been awhile since i did mine.(I ACTUALLY HAD TO LOOSEN THE CAM HOLDERS.TO LET THE CAM COME UP SOME.)Just be careful.Let me know when you crack into it and see.
Joe
I won't have time until probably Sunday afternoon. Should I try any kind of engine restorer until then or is it probably not worth it?
97 procharged Cobra
09 Buell 1125R
Former owner of:
Joe
Sure thing. Thanks for the help. Do you know of any brands that have been known to work?
97 procharged Cobra
09 Buell 1125R
Former owner of:
