Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: Turbo question..
    Question Turbo question..
    Hi guys.
    I have a 97' ,Zetec Contour,2.0L,DOHC and would like to turbocharge it. What is the best choice in doing that? I have rebuilt the engine with JE 10.5:1 Forged Pistons (85.00mm bore) and Eagle "ESP" 3-D H Beam Connecting Rods - 5.483".
    Since my compression went up , how much boost can I put in it? I heard from a couple of friends that you need a lower compression to run about 20PSI.
    Can I run about 10psi , or is my compression to high for the stock valve cover??
    Aug 2001
    Villa Park, IL
    19,625
    Quote Originally Posted by acontour View Post
    Hi guys.
    It is not the valve cover you should be worried about...it is the head and gasket.
    2008 Mazdaspeed3 Sport "The Angry Goose"
    2000 SUPERCHARGED Ford Contour Zetec- sold 10/20/05
    "He's not the Stig, but the Stig's Mexican cousin!"
    Aug 2002
    Southeast WI
    1,715
    Just look at the Focus forums. The SVT Focus is running high compression. They are doing daily drivers at 15psi.
    If you have good tuning and have it intercooled, you should be able to handle 15psi. I sure hope you have a MTX though.
    HTH,
    BP
    --'96 GL * MTX Zetec-- SOLD! 3-12-2011
    --- '06 Mazda 6s * 3L Duratec * 6-speed ATX * Lapis Blue ---
    FOR SALE >> T3 Super 60 Turbo - Coated Focus Manifold - 42# FRPP Injectors - Focus CFM Throttle Body << FOR SALE (PM me)
    Quote Originally Posted by ButtonPuncher View Post
    HTH,
    BP
    Yeah , I have an MTX tranny. I'm still in the process of "breakin" in the engine , than I will most likely get a turbo. I heard a ball bearing turbo is better. Is that true?
    97' ZETEC Contour, 2.0L, 16V , DOHC ,VIN 3,MTX75 ,5 speed
    Mods: JE 10.5:1 Pistons,Eagle Rods,Custom SVT Longtube headers,Spec Stage 2 clutch, Air intake,Mangaflow full exhaust,ThunderVolt 8.2 ,Accel coil,Aeromotive FPR,24# inj ,VMP tune with X3.
    Aug 2002
    Southeast WI
    1,715
    You've got a lot of reading/research to do...
    A ball bearing turbo is better in that it will spool faster. They are also MUCH more expensive.
    If you are sticking with the stock head/intake, you will probably want to look for a:
    T3-60
    GT28R
    For a FRPP or CFM head with turbo cams and a FRPP intake, you would want a:
    T3-S60 (Super 60)
    GT28RS
    (The GT turbos are ball bearing turbos.)
    I should also mention a couple of Mitsubishi turbos, but I don't have the info in front of me right now.
    HTH,
    BP
    Mar 2004
    Louisivlle Ky
    6,934
    I have a T3 Super60 on the car right now. and at 13PSI of boost its absolutly insane. its probably the best option for the zetec for the price. Also if your interested i can build you a turbo kit for the zetec contour. PM for more details.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    T3-60
    GT28R
    T3-S60 (Super 60)
    GT28RS
    HTH,
    BP
    Yeah I know I'm researching everyday like crazy.
    Thanks a lot for your help.
    Aug 2002
    Southeast WI
    1,715
    Sure!
    Also, pick up a book called Maximum Boost by Corky Bell. It is a wealth of information.
  9. #9
    Mar 2004
    Louisivlle Ky
    6,934
    Sure!
    its an awsome book. barnes and noble carries it so its pretty easy to find.
  10. #10
    Nov 2005
    nashville,tn
    75
    Hi guys.
    i'm on 5 psi...i got pics if you want to look at.....do you have a myspace?
    96' contour SE
    ________________________
    TEIN Lowering springs, dual exhaust,
Page 1 of 2
1 2 LastLast
