Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: Noob question about hard shifting (ATX)
    Jan 2005
    Cleveland Hts., Ohio
    28
    Default Noob question about hard shifting (ATX)
    Hi, I have a 98 zetec and would like to end the hard shifting for good. I searched the old forums but wanted to ask a couple question myself.
    1. I did a fluid change about a month ago, I planing to do it again before winter (I do a lot of hard driving). So whats better for my trans of 133k on it, High mileage ATF or Mobile 1 syn ATF.
    2. I'm buying a trans cooler this friday, what style is the best and is bigger better when it comes to the trans cooler.
    3. I'm ordering a TSS from ford friday, there's no codes coming up what else should I buy/look for to help the shifting problem.
    Thanks in advance
    Deshaun
    You should also get a valve body that has been rebuilt with Sonnax valves.
    This will solve lotsa problems with the CD4E.
    Check the CD4E FAQ for details, and search the old forum for a supplier of the valve body.
    I believe that Axiom was one supplier.
    1997 Mondeo Ghia 2.0 ATX
    Sep 2002
    St. Louis, MO
    2,633
    need to clarify the conditions under which the harsh shifting is occurring.
    If it's only the 1-2 shift and can occur anytime, it's probably the TSS.
    If it occurs only after extended driving (over 20 minutes), your valve body is worn out. If so, the cure is the VB Ziyad described along with (probably) an new torque converter. An add-on cooler will prolong the life of the replacements and the transmission itself.
    Just BTDT. See my posts in the old forum (and maybe a few here in the new one).
    Steve
    98 Contour SE Sport 2.5 Duratec ATX Was the wifey's car, now it's mine - 170K
    89 Taurus SHO - Retired at 249K miles
    94 SHO ATX - 240K
    1997 F-150 5.4L E4OD - The Workhorse 170K.
    2007 Mariner AWD - Wifey's new ride.
    Jan 2005
    28
    Quote Originally Posted by projectSHO89 View Post
    Steve
    Its delays from P to R and D, also hard shifts when going into 1>2 only (does it all the time),the others are fine
    Family Guy Quote of the month
    Peter: Oh my god, Brian, there's a message in my Alphabits. It says, 'Oooooo.'
    Brian: Peter, those are Cheerios
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by deshaundsm View Post
    Turbine Shaft Speed Sensor.
    Edit. TSS links.
    http://www.contour.org/ubbthreads/sh...fpart=all&vc=1
    and this
    Mercon/Dextron III is fine for ATFluid.
    "Entiendo un poco espaņol"
    Jan 2005
    28
    Quote Originally Posted by Tony2005 View Post
    Cool thats what I was hoping for, the valve body would me a arm and a leg if it was that.
    http://www.transmissionspecialty.com/parts/DM/CD4E.htm
    Read the Sonnax info...
    Bump in 2nd or 4th, soft or harsh shifts 2-4 Accumulator Piston
    Soft, harsh or delayed forward engagement Forward Accumulator Piston
    Soft or harsh reverse, delayed engagement Low/Reverse Accumulator Piston
    Sep 2002
    St. Louis, MO
    2,633
    I sincerely doubt that a TSS will fix your transmission.
    Sorry.
    Steve
    94 SHO ATX - 240K
  9. #9
    I know this is gonna sound retarded. I have been hearing about the rebuilt valve bodies from the CD4E. Ive looked and I cant find a price.
    What does it actually do. Sometimes my car has trouble shifting from 2 to 3rd when in drive. It kind of bucks. Ive stalled it once already by trying to push it seeing what it will do.
    Any ideas?
    Thanks Guys
    2000 Mercury Mystique
    ED Molded Bodykit
    Lots of Custom Mods
  10. #10
    Jan 2005
    28
    Quote Originally Posted by 2000myst View Post
    Any ideas?
    Thanks Guys
    what he said cant find much of a price on those websites, I even googled CD4E valve body, with little help.
