I was wondering is it my head lamp or all contour light is not that bright at night? I got my lamp brand new about 8 months ago and it wasn't that bright at first.
have you done the brights bulb in the low beam socket? that makes a world of a difference. search around for that. all you have to do is cut out the two tabs on the bulb connector on the bulb to make it plug in to the low beam wire harness.
i warn you not to buy "high wattage" bulbs like 80W(low) 100W(high) as they can melt your wire harness. most people just get silverstar ultra or reg. 9005
here: http://www.contour.org/ubbthreads/sh...&o=186&fpart=1
-JON 99 CSVT T-Red. #2437
www.myspace.com/ripscottfrost
00 SVT Silver Frost/Midnight Blue #1321/2150
99 Cougar V6 5spd Spruce green - SVT powered!
03 F150 4.2L 5spd Supercab Black
I guess I have a thing for V6's with manual transmissions?
www.shineyphotos.com
So this is what I do, the 9006 low beam connector (brown), cut the little two tab with the toe nail cutter, put a 9005 bulb in there and that's it?
What do you mean when you said "i warn you not to buy "high wattage" bulbs like 80W(low) 100W(high) as they can melt your wire harness." Like don't get any bulb that has 80W or higher for the low beamn and nothing higher than 100w for high beam?
don't go on ebay and buy high wattage ones. OEM low is 51w and high is 60w. silverstar highs are 60w. thats what i meant. don't touch the wire harness on the car. look at the bulb out of the car and on the connector you will see 2 plastic tabs inside. cut them out or shave them off with a small razor blade. (not the metal tabs). the low beam has only one tab.
I just cut the wires and spliced in new pigtails that I picked up for 9005 bulbs.
He means don't get the high wattage bulbs (80w low beam and 100w high like you figured) because they draw too much power. You'll be fine with the regular 9005s or silverstarsI think those are closer to 50w like a normal bulb.
the silverstar ultra 9005's i have sitting here are 60w. the OEM ones that came with my new ford headlamps sitting on my bed are as stated above.
Ok I already did it and tried it. I love it is so much better. Thanks. By the way the 9005 bulb is 65W, so is 100% safe right? I'm asking because when I went to buy the bulb all of the people at service they said don't do it because the bulb will blow if I put a 9005 bulb into the 9006 harness.
you shouldn't have any problems
one more question. What's a nice set of bulb that have a nice blue look? Or purple if it look like those BMW. I think the purple you have to have projector right?
