big problem!!!!
ford zetec2
nashville,tn
I heard a clinging noise up under the hood... left the car running, went to check it out....the pressure pipe was hitting against the frame.. so I pull it away and a spark hit the coilpack. i guess it gounded out the wire, i dont know.. and the car died..when to start it nothing....remember when you turn the car on the on position the check engine light comes on..well mine dont come on and the fuel pump is not buzzing
have you checked the mega fuse or any other fuses yet? More than likely that is where you'll find your problem.
You checked all the fuses and they are all good?
On the power wire that connects the battery to the starter to the altenator, there is a mega fuse. You'll find it just underneath the throttle body and against a hard plastic tray holding the wiring harness. Did you check that?
Is the grounding wire still connected?
Are you getting power into the PCM?
