Results 1 to 5 of 5
Thread: want to upgrade front brakes to 278mm
    Default want to upgrade front brakes to 278mm
    I've got a 96 tour gl (zetec w/atx) and 15" rims. I want to upgrade to the larger 278mm rotors found on the SVT and some others. I've scoured the forums and as I understand:
    1) The larger brakes will fit under my 15" rims
    2) All I need is to get the caliper mounting bracket for the larger rotors and the larger rotors.
    Is this correct?
    thx
    2000 CSVT (2102 of 2150)
    96 GL Sport
    Zetec/Auto (out to pasture )
    If you get bored: what is my ip address | encrypt text messages
    Mar 2002
    NJ
    942
    Correct.
    Sep 2000
    7,295
    Make sure you get the brackets for the LATE SVT or the large Cougar. The brackets for the EARLY SVT won't work with your calipers. You can do it with the early SVT parts if you also use the early SVT calipers.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
    May 2000
    Lucas,Ohio
    714
    On the Cougar cast into the caliper bracket - 15 for the correct one.
    I helps when grubbing around in the scrap/junk yard.
    Paul
    98 Mystique LS 2ea (07/97) back-up(08/98)
    Wink UPDATE
    I just got done upgrading my front brakes. Easy!! mod. Another thread I opened has more info:
    http://www.contour.org/ceg-vb/showthread.php?t=21723
    96 GL Sport
