Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: how to get rid of blow by!!!!
    Nov 2005
    nashville,tn
    75
    Unhappy how to get rid of blow by!!!!
    heres a question for everybody? how do you get rid of blow by?
    96' contour SE
    ________________________
    TEIN Lowering springs, dual exhaust,
    Mar 2004
    Louisivlle Ky
    6,976
    Quote Originally Posted by ford zetec2 View Post
    you can never completely get rid of blow-by. if you have excessive amounts the only way to fix that is to rebuild the engine. you have to hone the cylinders and install new piston rings.
    Why do you ask?
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Nov 2005
    nashville,tn
    75
    Quote Originally Posted by striker2 View Post
    Why do you ask?
    wellmy turbo car has blow by and Im trying to bring the smoke down....
    96' contour SE
    Mar 2004
    Louisivlle Ky
    6,976
    how much smoke?
    Nov 2005
    nashville,tn
    75
    how much smoke?
    I got a tube from the valve cover runinng up under the car.....and it smokes at idle a little..and when i go into boost it pours out...
    96' contour SE
    Mar 2004
    Louisivlle Ky
    6,976
    i bet you dont have as much blow by as you think. im betting your pushing boost into your crankcase through the PCV system. i had to put a one way check valve between the intake manifold and the PCV valve to make sure i didnt pressurize the crankcase with boost.
    Nov 2005
    nashville,tn
    75
    what????
    96' contour SE
    Mar 2004
    Louisivlle Ky
    6,976
    what????
    no offense but you clearly have no clue how it all works.
    The PCV system vents the pressure from blow-by in the crankcase back into the intake manifold. when you pressurize the intake manifold with boost the air will go backwards through the PCV system until it reaches the crankcase. the PCV valve is supposed to prevent this BUT it does not seal nearly well enough to do so in our application.
    when you add boost to the crankcase all the pressure has to go somewhere. that happens to be out the valve cover vent (which really should go through an oil separator and back into the air intake before the turbo).
    my solution:
    i took an extra vacuum brake booster check valve (which seals completely) and installed it in the PCV system so that when under boost it would block off the crankcase.
  9. #9
    Nov 2005
    nashville,tn
    75
    my solution:
    i'll try that.. but will it smoke out the tail pipe
    96' contour SE
  10. #10
    Mar 2004
    Louisivlle Ky
    6,976
    it should not because you are not pressurizing the crankcase anymore so there should be minimal oil/air coming from the valve cover vent back into the intake. also what ever oil is left will get burned during combustion.
    I am curious about what turbo and how much boost you are running though (im sure you have mentioned it before)
Page 1 of 2
1 2 LastLast
