My fuel pump needs to be replaced and i already have everything all i need to know, is hjow to change it... do i have to drop the tank or take off the back seat?? does anyone have a how-to on this??
Thanks,
RObs
Thanks,
RObs
Car- 2007 Star Fire Pearl
Lexus IS250 6MT
Old Car: 99 Contour Zetec with PLENTY of Mods...
Car Club- Myspace.com/HiProfile
you go through the back seat. its quite simple. havent personally done it but i have looked at the ford cd. dont have it right now or i would post it for you. you might looking at autozones website.
First you will need to get the gas out of the line....I started the car, pulled the fuse under the hood for the fuel pump, and let the car stall out. Also pulled the gas cap off.
Almost forgot to mention this will be easier when your gas is under a 1/4 of a tank.
1. Pull out the back seat (clips)
2. Pull off the rubber cover for the fuel pump (has wires going into it)
At this point you will need to cut some "slits" in the sheet metal surrounding the hole for the pump. Then bend the "tabs" you made up so the pump can slide through it
3. Buy a fuel line disconnect tool....plastic ones work great
4. Slide the line off
5. Rotate the clip holding the housing
6. Once the clip is out you can rotate the housing and slide the pump out
Just have to reverse the order to install it. You will have to bend the "tabs" back so the rubber cover will go back on.
2008 Sunlight Silver Mazdaspeed3 Sport->"The Angry Goose"
2000 SUPERCHARGED Ford Contour Zetec- sold 10/20/05
Some pictures in the old FAQ.
http://www.contour.org/mods/mods.php...o&displayid=39
"Entiendo un poco espaņol"
we just changed the pump and no fuel is running through... we swapped out the relay and checked all the fuses and nothing..... what can be the cause of this?? the pump isnt delivering fuel we listen and we dont hear the pump working when we turn the ignition...
Lexus IS250 6MT
check for power and ground at the pump (the connector on top should be gould enough since you dont want to take the pump out unless you have to). that would be my first step.
You can use a battery from a 12v or 14.4v cordless drill to test the pump itself. A couple of alligator clips from the battery to the pump and you'll know right away if the pump is good or bad. A circuit tester will tell you if you're getting juice to the connector.
If home is where the heart is, then I'm out of place.Originally Posted by m!key
Lexus IS250 6MT
we also tried to shake the connection while turning the key and nothing.... we sprayed some starter fluid in the TB yesterday to see if that atleast lets it start and it started but stalled right after that. we have no idea what the hell it could be and im going crazy having to ask for rides to work and stuff.... any1 down here in miami that can help me out?
Lexus IS250 6MT
one thing that i should have mentioned that should be checked is the fuel pump inertia shut off switch. its located behind the drivers kick panel. theres a little access hole that you can use to make sure the little button on top is dushed down. check it and if it clicks try starting the car. if not then you need to go to fuel pump.
This is from the 97 Ford CD so the colors may or may not be exact. however the placement in the connector should be the same.
