Con-Man
Okay Zetec Family here is my problem. I have a coolant leak coming from the passenger side front. I checked under the car seems that the leak is coming from over the air compressor.I checked the pipes didn't find anything.I just changed my timing belt and water pump about 4 or 5 months ago. This is what the strange part is it only leaks when I park down hill. My drive way has a little down hill slope and sometimes I will park the car on the slope that is when it leaks. If the car is park in a flat area it doesn't leak.
Also it only seems to be losing the coolant that is in the coolant tank. Once all that coolant in the tank is gone it stops leaking. It doesn't take that much coolant to fill it back up. Let me know what you think. Thanks
