Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 21
Thread: Newly sanded headlights!
    Thumbs up Newly sanded headlights!
    Wow, just wow. I just finished this up recently, and I got pics:
    This is the passenger side held up to the drivers side, guess which one was done?
    The following two were taken at the same time in the same light with the same bulbs in each.
    I really can hardly believe how much of a difference about an hour of work made. Here's the process I used:
    1. Cleaning with Bon Ami glass cleaner
    2. Turtle Wax rubbing compound
    3. 1000, then 1500, then 2000 grit sand paper
    4. Turtle Wax polishing compound
    5. Maguier's liquid wax.
    To anybody who has clouded lights, you really need to do this, it's so easy, and does such a huge amount for your car. I was even out driving at night before I finished the other, and at one point, I couldn't even see the drivers side light, but could easily see the sanded side!
    Cardomain page!
    '97 Contour - white - zetec - mtx
    mods: led clock, short shifter, custom fabricated shifter knob, cold air intake, basic stereo/speaker setup, partially painted interior (work in progress), mesh grille, straight piped exhaust
  2. Default
    I plan on doing this soon. Just today I picked up a brand new headlight from Steve Tousley, but it makes my other one look horrible. (or even more horrible) I couldn't afford the other side, so I will sand it. Once I can afford the other one, I'm ordering a new one.
    Sep 2000
    Louisville, Ky
    9,565
    Looks tons better! I sanded mine on my 99 earlier this year and the improvement was definitely noticeable.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    Quote Originally Posted by matt0534 View Post
    you should've gotten one off a junk yard car and done the same thing on both of them. woulda saved you a lotta money.
    Cardomain page!
    Oct 2007
    Moreno Valley, California
    69
    I'm glad that you did clean your headlights and posted your results. I was just about to replace them because they're so dirty. But if I can clean them the way you did and get results like that, I'll do it.
    I do want to make sure that by the steps you posted, sanding them will not scratch the lens. I don't want to scratch the lens.
    1996 Ford Contour GL
    2.0L 4
    -cyl. Zetec (125,000 mi.) / 5-speed MTX
    Motorcraft 200-amp Alternator /
    Optima Deep Cycle Battery (yellow top)
    Custom 10-speaker, 3-amplifier sound system
    Quote Originally Posted by Lavell View Post
    ah... its sandpaper.... it "scratches" off a layer! I take it you haven't worked with wood much have your or body work?
    Oct 2007
    69
    You're absolutely correct. I have knowledge and experiences in computer building and repair, but I know nothing about wood or body work.
    Quote Originally Posted by StealthWyvern View Post
    2.0L 4
    Sorry didn't mean to sound like a ass or anything but by sanding your simply stripping off a layer of the light.
  9. #9
    Oct 2007
    69
    No offense taken.
    That's good to know. Thanks for the info.
    2.0L 4
  10. #10
    I just did mine. I don't have pics but they went from really yellow and cloudy to clear and sharp.
    I used 1000 grit followed by 2000 both wet. I spent about 10 minutes sanding per grit per light. Then finished with Meguiars PlastX lens cleaner and polish for about 5 minutes. I would suggest starting with 600 to get out more of the rock marks. and using a 1500 to save some time.
