Results 1 to 4 of 4
Thread: Question on clock install instructions...
    Default Question on clock install instructions...
    I just obtained a clock from the yard. I've gone through the instructions many times, but I have one question. I've looked at the clock plug and the radio wires, and it seems like I don't have a white/green for the radio.
    What should I look for? I believe this is for the dimmer.
    Here is what the radio connector DOES have:
    orange/black
    black/green
    yellow/green
    blue/black
    black/green (again??)
    yellow/red
    white
    I have all the other clock wires figured out, I am just not sure where I get the dimmer wire from.
    Any hints, I'd appreciate it. Thanks!
    Erick --
    Toreador Red/Prarie Tan 2000 SVT - #0887
    K&N | knauberized | FSVT 5 spokes | Magnaflows | Alpine | Pre98 Clock
    | Pre98 Console
    Next up - Fixing tire problems! | Pre98 Dash | Gentex Mirror
    I got it. I just ran my volt meter across the wires until I figured out what they were. White/green should be for the dimmer, but on mine it was blue/black. Just for future reference if anyone has one messed up like mine.
    Also, there were 2 ground colored wires, but only one was truly a ground.
    I got lucky, my clock had the PATs light in it, so I just used the existing PATs wiring for that, and it looks and works like a champ now.
    Erick --
    | Pre98 Console
    If you pulled that info from the how-to on the main page, you'd see the updated info that says how on 99-00 models, the wire color is different.
    The entire dimmer switch was redesigned in 99. It allows the interior lights to be turned on by clicking the switch all the way over.
    98.5 and lower only controlled dimming.
    1998 SVT Contour (B/MNB) #542 3L
    2000 SVT Contour (SF/MNB) #1533
    2003 BMW 540i M-Sport (6 spd)
    2002 Lexus IS300 SOLD!!
    anyone have a how to on this the archives are still down
    2000 CSVT T-red/tan. FOR SALE
    1998 CHEVY SILVERADO 5.7l, 14bolt sf, 3.73 gears, Wheatley custom tune.
