After alot of research I decided to upgrade my setup more. I ready to push it to the limits of pump gas.
I am going to purchase two items which will give me the beast I want.
I am buying a Turbo Xs DTEC boost controller and a game boy sp and will install it in my car. I will have full adjustable boost levels even gearing and rpms. I will also have a knock sensor light which will help me see detonation since the car is so loud under the hood. And the knock sensor is adjustable so it can learn the engine normal noise background. This peice will be give me the straight line performance from a standstill.
http://www.modernperformance.com/all...ers_DTEC.shtml
And at the same time I will install my larger turbo 60-1 Hi Fi using the TO4E housing but pushing 10 percent more air then the garret 60-1 and still using smaller housing. I will do the .82 AR turbine housing with a stage 3 or 5 wheel not sure yet. But the turbo is good for 520whp so we will see soon.
http://www.turboneticsinc.com/turbo_60series.htm
Any advice will be taken because this will set me back 1300 dollars and I hate to do it three times........lol
Oh and I will seperate the gameboy monitor and mount it in the cupholder area with a custom bezel and I will extend the wiring to mount the control panel in the glove box and I will have a DC to AC converter installed to....
will be nice.......
Love the new boost controller! Finally someone will spend the $ it takes to make max power per gear to minimize wheelspin. You'll probably have to put the soft spring back in the wastegate though to have a hope of boosting in first gear.
