are they the same
low2earth
is the zetec motor in the focus the same as the contour? like would the same things work for it
somethings but not all.
short ram intakes will work
2000 focus svt fuel pumps
certain FRPP (oil pump, cam gears, maybe a few others)
Intake manifold with some modification
throttle body with modification
engine torque damper(i think)
ignition coil and wires
cams(though make sure, due to vct and non vct)
Others may come in with corrections for me or add things. :shrug:
no, as the focus(and escorts, though some are different none will work) route the header under the middle of the oil pan. the contour(and zetec cougar) route it under the far passanger side.
You could use either the cougar header and down pipe or a shorty header, but you would have to get a custom down pipe made.
cougar header : http://www.contour.org/ceg-vb/showthread.php?t=8270
search ebay or other focus/escort sites for a shorty header (zxtuner.com is one)
but the cougar header will work just need a down pipe correct? but header its self will work just not the focus. did i understand that rite?
a shorty focus header will work, nothing else(from the focus exhuast)
the cougar header comes with a down pipe that will work,
oh ok thanx cuz i really wanna get a header for my 2.0 zetec but doesnt seem like i can find them. but i found one for a focus zetec for 100 bux so i wasnt sure.
