but why would you do covers when you could simply replace the contique pedals with those nice drilled ones out of a late model cougar???? simple to do, plug and play, no drilling required, the hardest thing is to take off the gas pedal assembly and replace it with the cougar one. add the dead pedal if you like. score a set at your local you-pull-it and you're good to go!
lakeside
on a lake in middle tn
'98 mystique ls duratec atx
de-badged, pin striped
pre '98 sail panels
b pillar black out mod
silverstars- turns and highs in lows
fogs on with parking lights mod
cougar pedals
