Does anybody know of a good Air-Intake for a 1996 Ford Contour GL. I would post this elsewhere but this is the only place it will let me post? Send links for the Air-Intake
Try searching. But here's a thread to look at:
http://www.contour.org/ceg-vb/showthread.php?t=13087
And fyi, your engine is the Zetec, which is what 99.9% of people refer to it as. And your car is considered a "pre98." So if you want to go searching to find out lots of cool things you can do for your car, you can go right ahead. Happy hunting!
Ian
Aircougar Performance
how do you know its a zetec? just because its a GL?
I knew a girl that had a contour that looked EACTLY like my pre98, it was a 96 GL, only difference between her and my car, is that she had the duratec.
In any case, if you have an I4 (Zetec) you can just for a simple Focus Zetec air intake, this fits with very minor modification, you just need a hose coupling between the pipe and the MAF. Search "Zetec intake" on ebaymotors.
If its a duratec, just search "Contour intake" and ones for the V6 will show up, all of those work on the contour.
Gone.
I love how my post is now helping so many people![]()
2003 Mazda 6s Speed yellow
1984 Pontiac Fiero 2M4
When you talk about 'air intake', are you describing the airbox with the filter inside? If so, imo there are two dgood options:
1) An induction kit (cone filter etc). Companies like Viper, K&N, Bomz do good ones for the Mondeo 4 cylinder Zetec and V6 Duratec engines, and I don't see why they couldn't fit your Contour GL.
2) A Mondeo ST200 airbox with flat panel K&N filter. This airbox has an additional air-feed to give better air flow. Not sure if the Contour SVT air box is like this, but I reckon it should have as it and the ST200 share many bits in the engine bay.
*** It's all about consistency! ***
***Semantics Is Everything***
*** Previously 88SVT ***
06 F150 Supercrew 5.4L FX4
98 SVT Contour #4362 Born 1/6/1998
69 Fiat 850 Sport Spider
67 Formula-S Barracuda
