Results 1 to 4 of 4
Thread: Zetec engine mounts
  1. Default Zetec engine mounts
    I dont know if this is where I should post. I really love my SE contour look, but I dont like the power. I can pick up a 3L duratec cheap; also able to get it put in for free (if it has the same mounts). I was wanting to know does the zetec have the same engine mount at the duratec 3L?
    99' Contour SE *100,000 Sept 12, 2006*
    Totaled *October 20th, 2006*
    Quote Originally Posted by CEM Rider View Post
    Buy a v6, You will need a whole new subframe, wiring harness, PCM, Tranny, cluster, and alot more. Waste of time and most importantly money.
    98' Contour SVT #2037- 132k, (blk/mnb) 04' 3L ported w/ SVT cams
    Chevrolet Blazer- 111k, mostly stock
    Hahaha. Search doesn't work for you?
    Short answer, no it won't work without time and money. You want a v6 contour, start with a v6 contour.
    98.5 SVT-187whp-whawhawheel bearing.
    96 ATX Zetec-alive but scarred!
    FS: $100 off $200 or more SPEC purchase
  4. Default
    Ok guys thanks for you reply
    *que end of thread*
