Page 1 of 2
1 2 LastLast
Results 1 to 10 of 18
Thread: New SCT Xcal 3
    May 2004
    Calgary, Alberta, Canada
    4,506
    Default New SCT Xcal 3
    Anyone use the new SCT Xcal 3? I want to get some tuning done on my cobra and im looking at picking up the new Xcal 3 over the old Xcal 2.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    Feb 2003
    Phoenix, AZ
    1,949
    You mean xcal3... or the livewire? I don't see any mention of an xcal3 on sctflash.com.
    morbid
    2000 Contour SVT (black)
    #61 (Sept 17, 1999)
    Oct 2001
    michigan
    2,598
    XCAL 3
    The X3 is the next generation of our handheld flash device, with increased memory, a larger screen, and most importantly it gives us a stable robust platform to add continued support for new PCM types as they are released from Ford, (and a platform to add future GM CAN support).
    http://www.evoperform.com/shop/index...roducts_id=242
    Basicly cheaper live wire, or an xcal2 with more memory and a few more functions.
    '99 Silver svt 3.0 Turbo 348hp and growing.....
    bp.powell@comcast.net
    US23
    MTX-75 rebuilding. Differential installs,shift towers,final drive changes etc... Great prices
    Apr 2007
    Plainfield, IL
    546
    so its just little features that aren't really necessary.....doesn't actually increase your tuning capabilities? What's the price difference?
    98' T-Red sold with a bad MTX-75
    Quote Originally Posted by 98TredSVT View Post
    Did you go to the linky?
    The SCT X3 has both end user adjustment and high speed data logging capability. Using the keypad, you can make changes to your timing, fueling, fuel injector size, and dozens of other parameters. You can also monitor and data log all critical parameters by both connecting the X3 to your PC and using the SCT Live Link software, or by using the built-in LCD display.
    Sounds like it is a bit more user friendly and easy to use then the Xcal2, does things you would need a laptop for on the Xcal2. Sounds pretty sweet to me
    00 SVT Silver Frost/Midnight Blue #1321/2150
    99 Cougar V6 5spd Spruce green - SVT powered!
    03 F150 4.2L 5spd Supercab Black
    I guess I have a thing for V6's with manual transmissions?
    www.shineyphotos.com
    Oct 2001
    michigan
    2,598
    Price is same as xcal2.
    US23
    May 2004
    4,506
    Uhh, at americanmuscle.com its like 30 bucks more. Small price to pay for having the better equipment.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    you guys need to check out sniper tuning. there program allows you to tune your own vhicle and download new tunes into your vehicle. it also data logs and creates a base tune as well. their system even allows for 2 vehicle tuning as well as dual power adder tuning. in my opinion this programing is way better than super chips comericalized tuning stuff that you pay way to much money for.
  9. #9
    Sep 2000
    Louisville, Ky
    9,565
    Quote Originally Posted by I8RICE View Post
    Most people would rather just have the best tuner available which is why they go with warmonger and the x-cal.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
  10. #10
    Mar 2003
    West Palm Beach, FL
    8,043
    Quote Originally Posted by beyondloadedSE View Post
    Fo sho! Tinkering with your engine on the fly is a sure fire way to roast a new install.
    No way I would attempt to dial in a 3L without a base or performance tune from Warmonger.
