Originally Posted by
Savior
So I was trying to order a set of nice-sounding mufflers to go with my new hi-flow cat and MagnaFlow resonator, but apparently there are a lot of different sizes/types available...
http://www.justmagnaflow.com/UniversalMufflers.asp
What size works best under our cars? Probably an oval-shaped one like the stock mufflers, right? But what size? I see:
4" x 9"
5" x 8"
5" x 11"
And how big should the tip be so that it will look large/noticeably not stock, but still fit OK in the SVT's rear-bumper cut-outs? Is 3" good?
Any suggestions? I'm not too picky on this as far as brand name or whatever, I just want some shiny mufflers that sound good and deep, a nice bump up from stock...
Trubends system works well in our cars - particularly the resonated system if you want to keep the volume down.
Hooked the old SE V-6 up to an SVT exhaust system and replaced the center res with a mid size 5x8 magnaflow. Sounded GREAT, but a bit quiet for some. Really came alive when 'on it', but didn't attract the constabulary much.
I did notice just a slight drone with that setup, but I think it could have been fixed by using the shorter 5x8 - which would also make the system slightly louder.
I have wondered at times what the Ten Commandments would have looked like
if Moses had run them through the US Congress.
