Results 1 to 8 of 8
Thread: Hey
  1. Default Hey
    Hello, my name is kyle i'm from around dayton ohio and i have a 97 contour v6. I just bought it a few days ago and i believe it needs a head gasket change..yay! I also have a 91 240sx with a swapped sr20det pushing around 275 horse. Of course the 240 is uncomfortable, loud, and is horrible in the snow. therefore i bought the contour for a comfortable daily driver and i hope alot of you can help me out and show me in the right direction here.
    again hey everyone
    Welcome........I'm considered new here too! BTW might look at that water pump first before replacing the head gasket....
    ASE Certified Automotive Technician/shop owner
    98 T-red/midnight #4933 (owned 5 years)
    no sunroof, no cd, no spoiler
    00 Black/tan unknown number
    05 Suzuki SV650S *for sale*
    Mar 2001
    Merrimack NH
    10,074
    Blog Entries
    13
    What is your Contour doing?
    Matthew
    1999 Contour SVT #410
    2008 Subaru Legacy GT Limited 5MT
    Sold: 98.5 Contour SE V6 ATX
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by Rouar View Post
    Welcome. Yeah, what he said! Why do you think you need a new headgasket?
    "Entiendo un poco espaņol"
    Mar 2007
    Sunderland, MA
    5,018
    Blog Entries
    7
    Quote Originally Posted by Tony2005 View Post
    Headgasket...hmm...isn't it usually the WP that takes a crap in these cars? Plastic impellers FTL
    Ian
    Aircougar Performance
  6. Default
    well.... I burn the coolant level from max to min in about 2-3 days and i have quite a bit of oil in my coolant and no leaks on the ground whatsoever.
    I'm gonna check compression just to be sure and so i dont have to change both of them at the same time
    Jun 2005
    Virginia, USA
    11,070
    Yes, that sounds like a headgasket issue. Do the el cheapo headgasket test.
    http://www.contour.org/ceg-vb/showthread.php?t=761
  8. Default
    Well, since I can't post anywhere else for some reason, I guess I will talk about it here....
    I checked the compression and it came back 190-200psi in all 6 cylinders, plus the plugs looked fine. I still have oil in my coolant. i guessing i have a cracked head? does anyone have any experience here? which one usually goes first?
