the pats system on a 2k contique is build into the PCM ... the PCM has to be programmed to recognize the keys ... so if youhave the SVT PCM, and it has to be from a 2k only becuase of the fuel system, then you can follow the instructions on the main site to program your keys to the SVT PCM
