P1744 - Is it still drivable?
Quick question,
Will the trans from a 4 banger drop into a V6 motor?
If not, can I get one from a .... V6 Escape or...?
Ok, did some homework.
No, the 4 banger trans will not fit a V6. it has a different starter setup/mount.
Still trying to find an answer for the V6 from another Ford/Merc/Mazda with same trans.
I realize this is a few years out of date, but the question needs answering.
The quick answer is no. The electronics and mounting varies.
I'm working on a project now where I'm replacing the 4 banger with a Sable V-6, and I've mated it to an Escape transmission modified to work with a v-6 Contour PCM. The big issue in my project now is the rear mount system. Tranny bracket is different from the Contour - I-4 or V-6, rubber mount design is completely different, and the alignment is slightly offset. I'm fabbing a hybrid mounting system from the two sets of gear that will offer solid mounting, proper balance, and just as importantly, proper elevation.
The 6 cylinder also has bigger clutch drums that hold more clutch discs to handle the extra torque of the bigger motor.
