Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: Water Pump :(
    Oct 2006
    Glendale,Arizona
    75
    Default Water Pump :(
    So today I was pulling into the parking lot here at my apartment and I noticed my oil gauge flickering and my check engine light turn on. Well thats when I look at my temp gauge and my temp was at 260 !!! well after I cooled the car down I looked around and i saw the belt had snapped on the water pump people were telling me to try turning the pump to see if it has locked up but I already know the answer my car has 125k so its WATER PUMP TIME anybody have any tips or advice on replacing it.
    1998 Silver Frost SVT #2506
    whats up man, i replaced my water pump when i bought my car, its pretty easy the only hard thing is getting the old gasket material off. Purchase the metal impellar from ctamotorsports.com or someone and ill be glad to help you out, i think we live pretty close by. let me now and ill pm you my number.
    Nick Nickerson
    99' t-red csvt
    illegal leopard skin seats :-)
    Feb 2003
    Phoenix, AZ
    2,196
    I'd recommend not just replacing the pump, but getting the entire assembly from Ford. I replaced the pump, only to need to replace the housing about 6 months later. Also, the pump assembly price is less than just an aftermarket pump. The kit comes with the housing and pump (pre-assembled), and it comes with the 2 large hoses. This is the revised one that doesn't fail like the early models... where the impellers crumble. Just to clarify, there's a reducer cone in the housing that can dislodge from the housing and cause problems. Also, this is good preventive maintenance -- replacing those hoses. Since I didn't have to mess around with removing the rock hard gasket material... I think I spent less time replacing the entire assembly... even though that meant I had to remove the UIM/LIM to get to one of the hoses.
    morbid
    2011 Edge SEL AWD (black) - daily driver
    2000 Contour SVT (black); #61 (Sept 17, 1999)
    3L with ADC turbo kit; 325hp / 338tq @ 7psi
    car is down with a broken tranny
    Oct 2006
    Glendale,Arizona
    75
    Thanks for the advice man do you know how long I should expect for this to take without running into anything major ?
    Quote Originally Posted by morbid View Post
    Sep 2003
    Tucson, AZ and the Bay Area
    234
    Are you sure the engine isn't toasted? Sounds like it ran hot for a while for the CEL and oil lights to be triggered.
    Greg
    00 CSVT turbo
    99 Cougar
    Oct 2006
    Glendale,Arizona
    75
    engine is fine it started up and ran
    If it runs good now (no flickering warning lights), you shuld be OK, I had to fix the same thing.
    1998 Mystique LS 2.5 Duratec ATX
    1985 Dodge Lancer ES Turbo 2.2
    1991 Taurus SHO, 45kmiles
    Just FYI, Napa sells the entire water pump assembly with the metal impeller, and keep it in stock. Don't remember the exact name, but just have the guy at the counter open the box and look. It was in a darker colored box IIRC.
    1999 Black Mercury Cougar V6 MTX "Sonic" - Future HPDE/Time Attack machine
    1999 Silver Mercury Cougar V6 MTX "Silver" - Future Summer Daily Driver
    1989 White Jeep Cherokee I6 4x4 "Tails" - Winter Daily Driver/Off-road adventuremobile
  9. #9
    Feb 2003
    Phoenix, AZ
    2,196
    Quote Originally Posted by hugoscsvt88 View Post
    Well.... that depends. Just pulling everything apart to replace the pump, you're looking at around 2 hours. Though... if you've never done a UIM/LIM rebuild, then you should do that at the same time. It only adds about 1 hour.
    If you're going to do the rebuild, you'll need:
    Gaskets:
    • EGR -> UIM gasket
    • IAC -> UIM gasket
    • Throttlebody -> UIM gasket
    • UIM -> LIM gaskets (2)
    • LIM -> head gaskets (2)
    • Injector o-rings (12 total, or 6 upper & 6 lower... depending on your year)
    Other:
    • Roll of shop towels
    • 2 cans of Berrymans carb cleaner
    Also.... if you haven't flushed your coolant system, you should also do that too, since you're going to loose alot of coolant when changing the pump. This adds about 1 hour as well..... if doing it, you'll need...:
    • 1 gallon antifreeze
    • 2.5 gallons distilled water (less is needed.. this is just to be safe)
    • 1 bottle of Waterwetter (optional)
    • new thermostat
    • thermostat housing o-ring
    • garden hose
    morbid
  10. #10
    Oct 2006
    Glendale,Arizona
    75
    Thanks for the heads up man I took apart the assembly and the water pump appeared fine the only thing i can thing of is the belt just got old and dry and broke but besides that I notices my water temp at 225 seems a little high I went ahead and replaced the thermostat today to, do you think the radiator flush would help at all ?
    Gaskets:
    • EGR -> UIM gasket
    • IAC -> UIM gasket
    Other:
    • new thermostat
    • garden hose
Page 1 of 2
1 2 LastLast
