Results 1 to 6 of 6
Thread: LED door lights
    Jun 2006
    Hampstead, Maryland
    1,258
    Question LED door lights
    Does anybody have any information reguarding doing a pre-98 door trim light swap to a 98+.( the light in the door handle area) was thinking about doing blue leds for all four doors. going to the junkyard on monday so is there anything sapecial i need to look for when getting this and any tips on how to do it correctly? like special wires etc....
    Thank you
    2001 Ford SVT F150 Lightning Black
    1998 Ford SVT Contour Silver Frost E0 #3455/6535 *sold*
    *lots of contour parts for sale please PM me*
    http://www.contour.org/ceg-vb/showthread.php?t=31994
    if you do post how to please good idea
    CSVT 98 #1862 of 6535 06/11/1997
    3.0,tw8mm,msds-h,2.5exhaust ,optimized y pipe, superchip,original svt cams, unorthodox udp,stage 1 spec clutch,optima yellow battery
    GTP 2002 no cat,original intake,mil eliminator,u bend deleted, 9.60 1/8 mille stock
    May 2006
    Plymouth,MI
    2,587
    Blog Entries
    1
    Yeah, there is just LED bulbs in the stock ones IIRC.. just pick up what color LED you want and hook it up
    '98.5 2.5L Mystique LS T-Red
    '98 SVT E0 BLK/MNB#1663 Port matched 3L
    Carbonfiber= Played out.
    1999 Silver Frost SVT - #2603/2760 Aug. 10, 1999.
    1998 Black SVT - #3035 Re-born 3/12/09
    1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
    1995 Ford Contour V6 MTX-sold @ 214,000km
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Aug 2002
    Burlington WI
    1,055
    If you have a 98+ which the original poster does and they did not use pre98 parts in the doors there is no wiring or clear piece of plastic for light to shine through. He will either need to get pre98 door plastic pieces or will need to follow the how to and drill the holes for the leds.
    2000 Black SVT with 114k Build # 1598 1\14\2000 egnine knock
    98.5 Black SVT with 47k miles Build #5683 Born on 4\15\1998 crashed... fixing
    PB600.1 Infinity Kapa 100.3se PCA 450 fiberglass tweeter pods
    2002 Jeep Wrangler X 3" lift with 33 by 12.5
