What king of wheel horspower #'s can we get with the sawp?
I'll tell you now b4 everyone else does....SEARCH There are alot of dyno'd 3L but I think they can range from 170-180 whp- 200's whp. I guess it just depends on the motor, mods, etc. I'm sure some of the 3L guys will chime in.
So much for the new newbie forum.![]()
00 SVT Silver Frost/Midnight Blue #1321/2150
99 Cougar V6 5spd Spruce green - SVT powered!
03 F150 4.2L 5spd Supercab Black
I guess I have a thing for V6's with manual transmissions?
www.shineyphotos.com
180 on a full 3l build. No SVT items.
180-190 is average...
180 with Full Stock SVT Exhaust
190 Without main cat, optimized y pipe.
My 3L made 204.3 whp / 188.9 wtq with my original build, 3L with split port 3L heads and SVT cams.
with minor tweaking I am at around 214whp now.
good to know........
2000 Black/Tan Contour SVT 3L
131 of 2150 - WeaponR Y-Pipe
MSDS X-Treme Coated Headers
18" BSA 259's - Torsen T2 -
K&N RU3530 - 8lb Fidanza
Spec Stage 3+ - Ford Racing Wires
182 FWHP 187 FWTQ Without a Tune
How so?
Most 3 liters get around 210-220 with a good amount of bolt on mods.
185-195 stock 3 liters.
Heck blackcoog was getting 230 at the wheels with every bolt on/upgrade possible.
The most important thing here guys is the tq increase. Since the 3l is over 210 and the 2.5l is at 170. HP is gained but you will mostly feel the tq when you do this install.
FS:65mm Throttle bodies - SE TB - Zetec TB
Never explain---your friends do not need it and your enemies will not believe you anyway.
