Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: Foglights
    Default Foglights
    I've got a 98 SVT with standard Contour bumper covers on it. I am looking to put some foglights in and need to know IF I find a set of OEM's do I get the w/o SVT style? Are the mountings different in the SVT bumper vs the standard contour? I have also seen where there is a difference between the pre 98's mounts and the 98 & on models. So when I am looking for foglights do I look for the 98 & newer style. I need the brackets and lights too. Any help out there? I've done some searches but have NOT found any definitive answers. Thanks
    Sep 2000
    Louisville, Ky
    9,565
    Im not sure how the non svt and svt mounting brackets were during the 98-00, but the 95-97 mounting brackets were different than the SVT ones for sure. However, they are pretty easily modifiable to make it work either way.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    Thanks, I THINK I figured it out, AND I just picked up a NIB set of OEM fogs w/ brackets and everything off ebay for $80.00 shipped!
    Sep 2000
    Louisville, Ky
    9,565
    Quote Originally Posted by funinak View Post
    Ouch! You overpayed. You can brand new OEM fogs and brackets from BAT for $24.50 a piece.
    Jim Hahn
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Quote Originally Posted by beyondloadedSE View Post
    thats backwards, the 95 to 97 brackets are the same as SVT brackets and the 98 to 00 SE brackets are different
    search the asthetics forum as there is a thread with pictures comparing them
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Sep 2000
    Louisville, Ky
    9,565
    I can assure you my brackets on my 96 did not fit my SVT fascia.
    Jim Hahn
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    ok here is the faq that csvt1214 put together
    the part the lamp itself is mounted in is the same for pre98s and SVTs .... the pre 98 have the "bracket" the fog lamps bolt to as part of the bumper and the SVT have a bracket that mounts to the bumper and then the fog lamp mounts to the bracket
    - 95 Mystique LS
    Post
    from what i've seen, the brackets on my SE look totally different from the SVT ones posted in a how-to.
    '99 Contour SeVT ATX - Orig. Owner
    *2.5L V6, 181k DD
    '04 Lexus RX330 - Orig. Owner
    '03 Nissan Sentra SE-R - Orig. Owner
  9. #9
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Quote Originally Posted by Yawak View Post
    yes they should be different
    - 95 Mystique LS
  10. #10
    Sep 2000
    Louisville, Ky
    9,565
    Which is exactly what i said in both my posts. I never said the lights were different. I said the brackets are different.
    Jim Hahn
